Engine does not crank - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 2 (permalink) Old 04-19-2011, 04:42 PM Thread Starter
Quoted: 0 Post(s)
Helping a friend with a starting problem on his 2000 D11 4.0 Litre.
Drove to the mall and returned a few hours later and when he tried to start the following happened.
1. Doors opened with the remote
2. Key in ignition and turned... All warning lights and chimes came on
3. Transmission in "P"
4. Tried to start and...
5. All dash lights went out and loud clicking noise from starter motor area and sparks seen at starter motor relay in fuse box
Fault tracing:
1. Battery is fully charged.
2. Engine can be turned over with a socket and ratchet on front crankshaft pulley
3. Starter motor removed and checked... All OK
4. All cables are good and not shorting to ground
5. Cut-out switch (push button style on firewall) did not trip
Any help in fixing this is appreciated as nearest dealership is 4 hours away.
rutmaster is offline
post #2 of 2 (permalink) Old 04-20-2011, 05:39 AM
Administrator
Quoted: 5 Post(s)
Do your friend a favor, don't touch it, don't even try to start it or you will be causing a lot of wire harness expenses. Have it towed to a good Rover Mechanic, not the dealer.
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
Disco Mike is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
heard a snap, starter spins, won't crank engine highfructosecornsyrp Range Rover Classic 3 03-07-2011 09:55 AM
Engine Immobilser or Crank Position Sensor tlblues Discovery Series II 7 11-09-2010 11:20 AM
97 Disco Engine Crank Over But Won't Start extremrovers Discovery Series I 20 03-28-2010 06:00 PM
engine will not crank all the way over jake24david Range Rover Classic 5 04-15-2009 04:09 AM
two belt crank pully for series engine tonkatoy189 Land Rover Parts and Vehicles Wanted 1 09-11-2006 12:26 AM
You may post new threads
You may post replies
