Old 05-09-2008, 07:01 PM   #151 (permalink)
got mud?
Jupiter Rover's Avatar
A3/b3 > A2/b2
at least i think that is correct...
2003. Discovery SE
the names Pete
Old 05-10-2008, 01:43 PM   #152 (permalink)
ohiorover's Avatar
I think the olive oil advice with the lucas additive was the most useful information on this thread.
ohiorover is offline   Reply With Quote
Old 05-10-2008, 02:32 PM   #153 (permalink)
got mud?
lucas fuel with an oil that meets ACEA A3/B3 rating
2003. Discovery SE
the names Pete
Old 05-14-2008, 08:09 PM   #154 (permalink)
pgf
Hi,
I had similar clicking - it turned out to be the valley cover gasket (which is a metal gasket) due to pressure build up in the top of the motor due to blocked PCV. Pretty simple to chekc your crankcase breathers !!
pgf is offline   Reply With Quote
Old 05-16-2008, 12:14 PM   #155 (permalink)
Default What grade of gas are you using?
What grade of gas do you use? If it is not 93 octaine..you most likely have a carbon build up on one of the valves.
I think engine flushing is a bad idea overall. Just change your oil every 3k. The gaskets on these trucks are weak to begin with..add a little solvent to them and boom...instant leak for life.
cbwhitley is offline   Reply With Quote
Any body doing electric hybrid in a LandRover? Adam in NYC USA Hybrid 54 12-23-2006 10:39 PM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 03:50 AM
Custom fabrication people.. I have a pair of turbos 02disco2 Discovery Series II 9 01-24-2006 07:53 AM
99 4.6 is superlocked and won't reset Spring Range Rover P38, Mk III and Range Rover Sport 9 12-05-2005 04:46 PM
Engine Flush 94 Disco1 honybears Discovery Series I 6 11-18-2005 09:38 AM
