Old 11-12-2008, 07:53 AM   #1 (permalink)
Default engine questions
When I Crank Up My Disco The Temp Gauge Is Always On Cold No Matter If Its 102 Out Side And My Engine Seems To Be Really Loud
For The First 20 Secs Or So Then The Temp Gauge Evens Out And The Sounds Goes Away! I Need To No What The Problem Is Because It
Wasnt Like That When I First Brought It!
rovermane803
rovermane803 is offline   Reply With Quote
Old 11-12-2008, 07:57 AM   #2 (permalink)
Rebuilding Rover
ArmyRover's Avatar
what kind of sound?
Also that sound slike normal operation on the temp gauge it takes a min for it to get a reading and to send the gauge to the appropriate spot.
of them." unknown quote.
(offending Austrailians since 2008)
http://www.wheelinrovers.com/
91 Range Rover Classic
90 RRC Parts truck
89 Jaguar XJ6
Old 11-12-2008, 02:32 PM   #3 (permalink)
Are you sure your coolant system is full and no air is trapped in the engine?
Go into more detail regarding the sound you hear.
Old 11-12-2008, 03:47 PM   #4 (permalink)
brian4d's Avatar
Check your OIL Level!
Brian Morgan
I bitch because I can, I can because I live in America.
2002 Discovery SE (Stock - No ACE, No SLS)
1995 Nissan Pathfinder SE (Sold)
1999 Chevrolet Cavalier (Red Bullet)
brian4d is offline   Reply With Quote
Old 11-12-2008, 06:45 PM   #5 (permalink)
yep...I had one that sounded like a diesel when you started it...sludge had built up in the engine and blocked the return in the oil pan...Theres a tiny filter or some sort of screen that can be clogged up and reduce oil circulation in the engine. When was the oil changed last? My mechanic recommends a strict 3k mile oil change schedule...Mine's a hundred or so past due on service...but definantely check the oil and get the oil changed soon if it hasnt been done recently...and have someone pull the pan and check that screen...you may even go as far as flushing the motor with engine flush or tranny fluid...theres some recommendations floating around here...I'm sure if I'm wrong someone will correct me...
Mike is the man when it comes to these things...I've learned alot from reading what he's put up here...
BamaDisco03 is offline   Reply With Quote
Engine Questions lazerusrm Discovery Series I 10 09-12-2007 06:02 PM
Any body doing electric hybrid in a LandRover? Adam in NYC USA Hybrid 54 12-23-2006 11:39 PM
P38 ..Non-Starter!! Fozzy Range Rover P38, Mk III and Range Rover Sport 25 04-12-2006 04:50 AM
Custom fabrication people.. I have a pair of turbos 02disco2 Discovery Series II 9 01-24-2006 08:53 AM
99 4.6 is superlocked and won't reset Spring Range Rover P38, Mk III and Range Rover Sport 9 12-05-2005 05:46 PM
