Old 08-26-2008, 02:19 PM   #1 (permalink)
boca disco's Avatar
Default Evap question help
Recently got a PO455 code-Evaporative Emission Control System Leak Detected (gross leak). Have done a search and read it can be anything from gas cap leak or some minor leak in evap system. Ive checked gas cap and browsed over all evap lines i can see and follow and havent really seen anything like loose conectors or anything.
Any tips or past experiences from any of you folks that can lead to a good starting point to start digging deeper. 04 SE7
2004 SE7
boca disco is offline   Reply With Quote
Old 08-26-2008, 06:45 PM   #2 (permalink)
only a testbook can do an evap test that can tell you if the evap leak is still present.
if it still says its leaking then you need a smoke machine to pressurize the system and check for a leak.
thats how all manufacturers are when it comes to evap leaks.
Tie Rod End question RageRover Range Rover Classic 8 09-14-2008 11:33 PM
A question about the hard tops LR3dirver4ever Defender 5 03-05-2008 11:20 AM
Radio Question 1994RoverLWB Range Rover Classic 3 03-03-2008 11:15 PM
MAF sensor housing question tcpfl Discovery Series II 2 11-12-2007 05:49 PM
Heck of a question (Non LR) Funrover The Lounge 10 11-10-2005 08:16 PM
