Old 06-20-2008, 05:46 PM   #1 (permalink)
brian4d's Avatar
Default Ever heard of this?
My brakes only squeek when I'm turning. Anyone ever heard of this?
brian4d is offline   Reply With Quote
Old 06-20-2008, 08:31 PM   #2 (permalink)
2002 Discovery II SE
Have you checked your wheel nut tourque?
Is it like a constant squeal or a squeak squeak squeak.
Alak is offline   Reply With Quote
Old 06-20-2008, 08:45 PM   #3 (permalink)
got mud?
Jupiter Rover's Avatar
Mine squeak every time I turn and brake into the driveway.. who knows. There probably just dirty.
DII
-- Pete
285/75 r16 Destination M/Ts
Old 06-20-2008, 09:13 PM   #4 (permalink)
Usually most brakes squeak when they are cold. If its a squeak squeak squeak, could be a warped rotor, or something is loose. Perhaps someone probably did the brakes and forgot the anti-squeal pads.
Old 06-21-2008, 12:18 AM   #5 (permalink)
boca disco's Avatar
Mine always start to squeak if I havent washed the old girl in two or three weeks and a lot of brake dust gets built up. Its like her personal way of reminding me she likes to stay clean.
2004 SE7
boca disco is offline   Reply With Quote
Old 06-21-2008, 04:08 PM   #6 (permalink)
No.
How many miles on the truck, when was the brake fluid completely changed?
Old 06-22-2008, 12:25 AM   #7 (permalink)
brian4d's Avatar
Default New pads
Mike, I've got 74,000. The brake pads were changed at 56,000. The Dealer didn't think it needed rotors. If I press harder on the brake it stops. Otherwise breaking is great. Break fluid, I have no idea. No abs light = happy camper!
Old 06-22-2008, 06:54 AM   #8 (permalink)
What do you mean if you press hard it will stop, what the truck or the brake squeak?
Not that it may or may not help this problem, but if you are clueless as to the fluid change do it anyway, about 3 pints will be needed.
Old 06-22-2008, 11:36 AM   #9 (permalink)
brian4d's Avatar
Default Brakes
When I'm doing a slow turn (left or right) I get a squeak, If I press on the brake harder (stopping faster) they stop squeaking. I was concerned it might be the squealers and I was going to need new pads and rotors soon, now I'm not so sure because it's been doing it for 4-5 months without any grind. BTW grind meaning No pad left, metal to metal. I'm not even sure if the pads have squealers.
Old 06-22-2008, 11:57 AM   #10 (permalink)
First of all, you don't have" Squeelers".
Sound like you have too much pressure on the calipers. I would suggest you go see a goo Rover tech and see what they find.
Old 06-22-2008, 02:05 PM   #11 (permalink)
brian4d's Avatar
Default Pressure
Well, squeelers vary by brake pad. My old Nissan truck had squeelers, quite helpful. It was the trucks way of saying, "This could be a $600 brake job now or a 1,500 brake job later!" I'll have them look at it. I'm sure they already see me coming from a mile away...
Anyone heard of RR sport s/c engines in a disco? stolenheron Hybrid 6 09-25-2007 11:29 AM
Anyone heard of this Expedition? wimp Off Road 17 11-09-2006 09:49 AM
Ever heard of Surco? LR123 Accessories 16 09-12-2006 12:28 PM
I still have not heard from the mechanic . . . CurvyRover Range Rover Classic 1 01-03-2006 06:53 PM
