Exhaust leak causing tick noise - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 5 (permalink) Old 09-06-2010, 11:41 AM Thread Starter
ewok's Avatar
Quoted: 0 Post(s)
I have a ticking noise coming from the passenger side of the exhaust manifolds due to an exhaust leak.
Is it worth the risk to try to torque the bolts in an effort to silence the tick? I worry I may crack the manifold or break a bolt as they are rusted...
Anyone work through this issue?
2001 Discovery II SE
92,000 Miles
ewok is offline
post #2 of 5 (permalink) Old 09-06-2010, 11:59 AM
hafaday's Avatar
Quoted: 0 Post(s)
most of the time the bolts break or the head shears off the bolt. is the leak at the head and manifold, or manifold and downpipe?
01 d2
Bill H.
The Rave on pdf's.
hafaday is offline
post #3 of 5 (permalink) Old 09-06-2010, 12:10 PM
Administrator
Quoted: 5 Post(s)
Nope, carefully remove the bolts and install a new gasket. The noise will go away and your performance may increase from a better air/fuel mixture.
Need Parts?
or call 203-770-1699
or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8,
British Parts of Utah,
Disco Mike is offline
post #4 of 5 (permalink) Old 09-06-2010, 05:15 PM Thread Starter
ewok's Avatar
Quoted: 0 Post(s)
The leak is at the heAd and manifold. I'll remove and will replace the gasket.
92,000 Miles
ewok is offline
post #5 of 5 (permalink) Old 10-28-2010, 06:43 PM
Fangul2000
Quoted: 0 Post(s)
Hello. I have an 04 Disco. I have been experiencing the same noise. I replaced the exhaust manifold gasket today (2 pieces) torked the bolts to spec and the noise is still there. It's louder when cold and also louder under acceleration. I can't see any visible leaks or cracks on the down pipe. Could it be the SAI? Thanks for your help in advance.
2004 Disco II SE7 Black (stock)
fangul2000 is offline
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Exhaust leak causing misfire??? fender1021 Discovery Series I 2 02-12-2009 06:08 PM
Exhaust causing knocking noise IWANTADISCO Discovery Series II 8 12-17-2008 02:19 PM
Tick...tick...pause...tick...tickish... kazakdog Discovery Series II 2 06-29-2008 05:33 PM
tick tock noise in dash pickps Range Rover Classic 4 02-19-2007 10:23 AM
I have a squeaking noise on tick over; it appears to be coming from the top drive bel 4x4disco Discovery Series I 1 12-03-2005 01:28 PM
You may post new threads
You may post replies
