Old 05-07-2008, 05:31 AM   #1 (permalink)
Default Faulty transmission
I just bought a 2004 land rover discovery (VIN: SALTWI9424A837297) from the US, it was shipped and just delivered to me last week Wednesday. A few days ago I noticed that my transmission was acting up, I had to rev my engine hard to get the car to engage in both Drive and Reverse. I also noticed that the M & S indicator lights were flashing repeatedly as well as the red light on the gear indicator cover. Called in my mechanic to have a look at it and he said it was the gear switch that had a problem, that it kept sending the wrong info to his diagnostic equipment e.g. when he selects a gear it gives either invalid or the wrong position i.e. when put in D it says invalid 1, when put in 2 it says P. when he ran the diagnostic on it it gave him the following codes:
1. Code001 – Position Switch monitoring.
2. Code002 – Gear ratio monitoring (3rd gear).
3. Code003 – Stall speed monitoring.
At the moment its not even accepting any gears at all, and had to have it towed
Please could you help what these codes mean, if he’s right about the faulty gear switch or what do you think is the problem
Thanks and best regards
olumide is offline   Reply With Quote
Old 05-07-2008, 06:48 AM   #2 (permalink)
Read my reply on your first post.
Old 05-07-2008, 07:01 AM   #3 (permalink)
cant seem to find it.
Old 05-07-2008, 07:10 AM   #4 (permalink)
just went down to the car now and the differential lock warning light is on even after the car hasnt moved since yesterday
Old 05-07-2008, 07:15 AM   #5 (permalink)
i think the post you talking about wasnt mine, though i sent you a private message. Disco Mike with this i need help cos' i've already ordered the switch from the US and want to be sure i havent wasted $218 on the wrong problem
Old 05-07-2008, 08:13 AM   #6 (permalink)
Get the exact fault codes, what you have posted are not Rover codes.
Have you checked the trannty fluid level?
Do you know how to?
Start the engine, shift from reverse to drive 2 times, put back in park and with the engine running check your fluid level thru the fill plug, add till it comes back out the hole.
Old 05-07-2008, 09:24 AM   #7 (permalink)
thanks alot for that but dont know how to do that, was actually looking for where to check the tranny fluid level but a novice to this and couldnt identify where and how. NEED HELP
1994 LWB manual transmission conversion kiato4 Range Rover Classic 2 04-25-2008 06:38 AM
1995 LWB Transmission shifting problem serge9444 Range Rover Classic 3 11-26-2007 12:26 AM
transmission problems scotth Discovery Series II 1 04-20-2007 11:06 AM
Transmission Service Kit AAXD Discovery Series I 7 11-17-2005 09:36 AM
Discovery Transmission and Transfer Case 1996 Land Rover Discovery 4.0 Rangie Mark Land Rover Parts and Accessories 2 08-22-2004 07:57 PM
