Old 05-14-2006, 09:37 AM   #1 (permalink)
LANDY96's Avatar
Default Few Electrical issues to sort!
I finally got the Cruise control working on my 99 DII. Thing is, I am not sure how it happened. So if some one could 'splain it to me! I also discovered that the Horn was not working. Found the fuse is burned. Replaced, it, and it worked ok, sounded muted though! While I was there, I removed the plug for the vaccum pump, inspected it, then put it back. Well, took it for a drive, and the horn stopped working, but the cruise control still works! I juggled the fuse, for the Horn, and then it started working again. A little while later it stopped again!
First Q.- Is the cruise control fuse, and the Horn connected? Can't tell by the "symbols" on the covers.
Second Q.- Since the Horn is intermittent, do you think it is a bad connection, or a relay problem.
Thanks!!
Eric The Red
93 Range Rover Classic
96 DISCO SE7 5-SPEED SOLD
96 DISCO SD 5-SPEED
-ARB Bumper
-OME 2" Lift
-2" spacers
-Safari snorkel
-15" steelies
Old 05-14-2006, 10:12 AM   #2 (permalink)
If your horn sounds muted, it may be failing which could blow a fuse at some point. I don't think the horn and cruise control are tied together on the same fuse.
Old 05-14-2006, 11:13 AM   #3 (permalink)
actually the horn and the cruise control use the same steering wheel wiring. ITs all on the same harness.
I wonder if the harness end isnt pulled where it contacts the steering column clockspring.
