Old 03-22-2007, 02:16 PM   #1 (permalink)
Default firing order DII
Can anyone tell me what the firing order is for a DII
deryck32 is offline   Reply With Quote
Old 03-22-2007, 08:21 PM   #2 (permalink)
Wink
1-8-4-3-6-5-7-2
trubrit is offline   Reply With Quote
Old 03-23-2007, 06:34 AM   #3 (permalink)
What did you do that makes you need the firing order? Did you try to replace all the plug wires at one time and get turned around.
Old 03-28-2007, 12:54 AM   #4 (permalink)
Default order
I need the firing order because I have #7 cyl miss firing after I checked the code with the reader it came up PO307 and I need to check the plugs also what are good plugs and wires to use
Old 03-28-2007, 12:57 AM   #5 (permalink)
does the order go left to right or first 4 on left and other 4 on right from front of engine
Old 03-28-2007, 06:02 PM   #6 (permalink)
on the driverside you will find the following cylinders from front to back
1 3 5 7
on the passenger side you will find
2 4 6 8
on the coils from passenger side to driverside from top to bottom it goes
8 5 6 1
2 3 4 7
Old 04-02-2007, 06:27 PM   #7 (permalink)
Default plugs & wires
Any one know which spark plugs and wires are better and where can I buys them
Old 04-02-2007, 06:58 PM   #8 (permalink)
Roverhound's Avatar
Champion RC12MC-4 , stock number 318 gap at .032
If you hate your truck get Bosch plugs.
For wires try www.kingsborne.com, really loved by the BMW folks and have been running in my truck great for a year or so. Avoid the bling prices of some of the other suggestions here.
It just doesn't matter.
