Old 12-12-2006, 05:22 PM   #1 (permalink)
He did what in his cup???
DevilDisco's Avatar
Talking First Leak!
This past week, I have been seeing drops of oil on the garage floor. They don't go anywhere because The floor is painted. Looked under the truck last nightl it appears to be coming from the transfer case. The support under it is covered in oil. Quite suprising how far the oil can creep along the chassis.
The oil is a carmel color, and stinks a little. Disco has 47,050, or it did when it was picked up for service. Strangely enough they are also doing the eval for the extended warranty, fixing the popping sound in the driver side window(regulator???) and possilby adjusting the striker panels (draft from doors). Magnecors and Platinum 4's are in the closet until after warranty is in place.
'04 Discovery SE7. Last of the best.
DevilDisco is offline   Reply With Quote
Old 12-12-2006, 06:32 PM   #2 (permalink)
Proud to be an Infidel
FlyWheel's Avatar
Wow ! A leak! A first??!!!
I suppose congratulations are in order!!!!
2001 Disco SE7
.......eventually they will run out of suicide bombers.....
FlyWheel is offline   Reply With Quote
Old 12-12-2006, 06:41 PM   #3 (permalink)
Thor's Avatar
This is the 50K rust inhibitor application. It has to start early as it only spreads when you drive.
Todd
Carpe Rangius Roverum
Old 12-12-2006, 06:58 PM   #4 (permalink)
Super Moderator
02disco2's Avatar
Sounds like the the output shaft has sprung a leak. Mine did the same thing and it was an o-ring or something. Covered under warranty.
Land Rover-less.
2006 Infiniti QX56 - Loaded
2002 Discovery II SE - SOLD!
Old 12-13-2006, 10:40 AM   #5 (permalink)
DevilDisco's Avatar
The dealership is looking at it right now. Actually the only thing that was rusty under there was the exhaust. The Chassis was not that dirty! Yeah touchless whashes.
Old 12-13-2006, 04:23 PM   #6 (permalink)
Betcha it's the transfer case drain plug. Tighten it another 1/8 turn. Wipe off the oil and see if that fixes it.
Rocky - Northern Nevada
04 Discovery S "JeepHerder"
Trans-Nevada-Trek Trailboss
RockyRon is offline   Reply With Quote
