Old 09-19-2006, 05:26 AM   #1 (permalink)
OSIYEZA's Avatar
Exclamation First - Second Shift Problem
My first attempt at finding help. My truck's a IIa 2005 XS TD5 Man - with a sticky gear shift I am not sure if the gearbox is still the R380. I know this was quite a notorious box for the 1- 2 shift.
It's worse on start up(cold) - takes quite an effort to shift into second.As it warms up - it gets better. It feels as if it catches - not quite in gear before it slips into second .Much less of a problem above 2500rpm .Land Rover dealer checked this out and said the tranny fluid was low....
It's driving me crazy...any ideas?
Regards
OSIYEZA is offline   Reply With Quote
Old 09-19-2006, 09:01 AM   #2 (permalink)
Searcaigh's Avatar
Gallery: 31
This is a manual gearbox is it not, puzzled by the use of term Tranny Fluid should it not be Gearbox Oil
Anyway check this link
http://www.ashcroft-transmissions.co...ory_5.html#a30
Gordon T. Smith
Middle East Land Rover Nutter
Searcaigh is offline   Reply With Quote
Old 09-20-2006, 03:04 AM   #3 (permalink)
OSIYEZA's Avatar
Default Thanx
You are so right....gear box oil....I will watch my P and Q 's !!
As for the info - gives me a great start - can take this to the dealer to check and insist that they look into it ! Thanks again !
Fredor
