Old 03-25-2008, 12:32 PM   #1 (permalink)
Default Flashing lights, PLEASE HELP
Hey everyone. Need your help with this one. Got into the 2002 Disco with 61,900 miles on it today. Shifted it to Drive and the "S" and "M" lights on the dash started flashing as well as the gear indicator for Drive "D" was flashing on the dashboard. It's sluggish as I hit the gas for the car to accelerate from a sitting still position.
Any ideas what the problem might be? Any codes I should search for and if so how do I pull up the codes on my radio?
Any suggestions are greatly appreciated. Is this considered three amigos?
IWANTADISCO is offline   Reply With Quote
Old 03-25-2008, 12:41 PM   #2 (permalink)
slangel's Avatar
No it's not the three amigos, and this has happened to me before. I just put mine back in park, turned it off, and then back on and it hasn't happened again.
Um codes on your radio....my codes are on a card in my owner's manual, or you can call the dealer to get it.
I think Cvc's goal is to make me vomit daily with his disgusting avatars.
slangel is offline   Reply With Quote
Old 03-25-2008, 12:48 PM   #3 (permalink)
What has your owner manual told you about this very common issue??????????????
How old is your battery?
Old 03-25-2008, 12:53 PM   #4 (permalink)
slangel's Avatar
Hehe.....I was thinking hasn't this been covered at LEAST a thousand times??
And call me silly but if the SES light isn't on - doubt you would get codes for anything.
Old 03-25-2008, 12:59 PM   #5 (permalink)
My owner's manual says, "If both the Manual and Sport mode lights(shown below) flash together, this indicates an electrical fault with the automatic gearbox. If the lights continue flashing after the vehicle has been brough to a hal and the starter switch has been turned off and then on again, you should see qualified assistance urgently."
I cut it on and off and it's still doing it.
Old 03-25-2008, 01:06 PM   #6 (permalink)
Just checked the battery. From what I can tell it's the original. I know in the past two years we've never replaced it, before that I'm not sure.
Old 03-25-2008, 02:00 PM   #7 (permalink)
Check the voltage between the terminals, if it is lower then 13.6 have it tested/charged or replaced. Your lights should go away having been caused by a low voltage problem.
If for any reason this doesn't correct it get back to us.
Old 03-25-2008, 03:58 PM   #8 (permalink)
Thanks Mike. Taking it in tomorrow to have that checked. Just FYI, I just went out to the Disco, cranked it and no flashing lights whatsoever. Could it be that it was just something that happened freakishly? I'll probably just replace the battery anyway since a 6 year old batter is probably due for replacement.
Old 03-25-2008, 07:23 PM   #9 (permalink)
Many times it is low voltage related, now if you were also into some shifting issues also, then it can still be low voltage or an internal electrical tranny issue.
Old 03-30-2008, 03:37 PM   #10 (permalink)
New Yawker in California
RudemanRB's Avatar
Gallery: 1
Don't think of it as a one time deal, I would suggest going to autozone or some shop and having them test your battery and Alternator (Autozone does it for free) can't hurt.
Rudy
RudemanRB is offline   Reply With Quote
Manual and sport mode lights flashing DiscoSE03 Discovery Series II 8 02-24-2008 04:09 PM
Flashing Radio Back Lights skrams Discovery Series II 1 03-06-2007 01:32 PM
Driving Lights or Fog Lights? 2002DiscoII Accessories 4 01-24-2006 04:48 PM
Hella 500 lights BIRD Discovery Series II 9 08-24-2005 05:31 PM
How to hook up auxiliary lights? BIRD Discovery Series II 3 03-15-2005 10:04 AM
