Old 03-03-2007, 03:48 PM   #1 (permalink)
Default Flashing Radio Back Lights
My radio / clock / dash back lighting just started flashing when the left indicator is on, but not when the right indicator is on and not when the headlights are on.
Any thoughts. Not a major problem but very annoying.
skrams
skrams is offline   Reply With Quote
Old 03-06-2007, 01:32 PM   #2 (permalink)
New Yawker in California
RudemanRB's Avatar
Gallery: 1
skrams
it sounds like you either have a grounding issue. or some how the wires are crossed or fused.
do a smell check near your fuse box and see if you smell any burnt wires.
but to me it sounds like it might be an issue with the left indicator light on the instrument panel is somehow fused or crossed with a wire or contact which connects to a bulb for the dash lights all the dash lights are tied together. which would dim the clock, Radio and Dash. I would carefully pull the instrument panel off. not to many screws.
This is just something I would think about and look into. I'm sorry if I steer you into the wrong direction
Trying to help
RB
RudemanRB is offline   Reply With Quote
