Old 08-11-2008, 12:39 AM   #1 (permalink)
Default Fog Light Doesn't Go On
I recently noticed my right side front fog light wasn't working, but left side was.
When I took it to the dealer to get an air suspension problem fixed, I told them to see what was wrong with the fog light, maybe just the bulb, but they told me it wasn't the bulb but the whole light fixture thing, they said it might've gotten messed up because water or something got into it, but how does that happen, don't Rovers go in deep waters and I'm sure it's not supposed to mess up.
Also, my other fog light that was working before isn't now, it lights up but it looks like the bulb like fell out to the side and not inside the fixture like it should be, but I'll have to try and take it out and check it. But yea any idea on the messed up fog light?
Shawon is offline   Reply With Quote
Old 08-11-2008, 07:12 AM   #2 (permalink)
Try replacing the bulbs on both side, if they still don't work then test to make sure you have power to the fog lights when your head lights are on low beam.
Old 08-11-2008, 09:20 AM   #3 (permalink)
how would i test if im getting power to the fog lights? when i have them on low beam (i assume u mean the dimmed lights before the actual headlight, when i press the fog light button it does light up but how can i tell
Old 08-11-2008, 10:28 AM   #4 (permalink)
Use a test probe and probe the wires to check for power.
Low beams, the standard low head lights, not high beams.
Oil light - I'm scared! jmrivera Discovery Series II 56 10-16-2008 06:37 AM
brake light bulb mystery chrisusvi Discovery Series I 3 02-13-2007 10:19 AM
1999 Discovery Light bulb guide darkknight1999 Accessories 3 03-22-2006 10:31 AM
How do I reset the ABS light jsaturnia Discovery Series II 2 01-19-2006 01:09 PM
ot an old one but true ot 75series3 The Lounge 1 11-15-2005 09:08 AM
