Hello:
I have a set of Hella aftermarket fog/driving lights mounted on the brush bar and they seem to come on for a short time then cut off. They are hooked up so that when the high beams come on & they are activated they will come on as well. Could the relay be bad as I have checked the switch and it appears to be fine or could it be the bulbs or something else? Thanks Jay |
#2 (permalink) | |
1) bad earth 2) bad relay 3) bad live connection to highbeam! By chance did you use a scotch block to connect the 2 wires? Scotch block = one of those blue wire splicer clamp thingies! Sounds like your either getting an intermittant live or and intermittant earth. Unlikely to be the relay IMO.
1992 K-reg 200TDI Defender 90 (Eva) MSN - Geobloke@hotmail.com There are a terrible lot of lies going around the world, and the worst of it is half of them are true.
Sir Winston Churchill |
My Hella did the same thing. They use a naked ground wire inside the assembly. It had shorted to the back of the lamp. Probably from a hard bump I hit.
I just wrapped it with electrical tape. Problem disappeared. |
