Old 06-17-2006, 07:42 AM   #1 (permalink)
From Chile with love
llano's Avatar
Default fog lights water
Hi everybody.
i bought my first Land Rover few weeks ago... from a friend.. and yesterday i noticed that the left fog light had water until the middle..
today i'm try to fix it. But why is this water inside?
sorry.. but i have no experience with Land Rover before.. and i need to know the mechanical stuff that i could do by my self..
thanks
Rodrigo Llano
Disco SII 2K
llano is offline   Reply With Quote
Old 06-17-2006, 08:04 AM   #2 (permalink)
The lens might be broken somewere that you can't see or the seals aren't any good....once you take the light out from behind the bumper you'll be able to see better. If everything looks perfect i would suspect it's the lens to housing seal...if so just run a bead of silicone around the outside of it to help keep the water out. Repalcements are about 185.00US so you might want to try sealing it yourself first......
Later, Dean
6cuda6 is offline   Reply With Quote
Old 06-17-2006, 09:18 AM   #3 (permalink)
llano's Avatar
thanks for that dean
.. another question.. what is for the water conection to the lights???
Rodrigo Llano
Disco SII 2K
Old 06-17-2006, 01:28 PM   #4 (permalink)
Depending on what model you have there will be a nozzle to wash the headlights....but i'm not sure if that is standard or only on the SE and SE7....
Old 06-18-2006, 07:44 PM   #5 (permalink)
There is a water drin pipe bulit into the bottom of each lamp to prevent noisture from building up, sometimes the drain tube plugs up and just needs to be cleaned out.
This is a common problem for Rovers and once you clean out the drain you'll be fine.
Old 06-19-2006, 07:53 PM   #6 (permalink)
llano's Avatar
thanks mike...
by the way.. where i could find an disco manual.. cheap.. or for free?
Rodrigo Llano
Disco SII 2K
Old 06-20-2006, 07:14 AM   #7 (permalink)
Originally Posted by llano
thanks mike...
Free or Cheap don't work when it comes to Rovers. You might want to go to e-bay and buy one of the shop manuals on CD's, they are good and usually inexpensive.
Old 06-22-2006, 06:08 AM   #8 (permalink)
llano's Avatar
jeap... i know mike... i just want to be sure..
Rodrigo Llano
Disco SII 2K
