Old 01-03-2006, 10:56 PM   #1 (permalink)
nice member
Default front brake job
will be getting 01' DII this weekend, plan on doing front rotors, plus pads..
that being said-never have worked on a rover. will i need special tools for this job,got plenty of all basic tools. do i need tamper-proof, or spline drive
style sockets... whats the skinny those dba rotors or OEM rotors.
and will kevlar pads work on OEM,if so what kind are they. thanks 4 help
REFERJOHN is offline   Reply With Quote
Old 01-03-2006, 11:08 PM   #2 (permalink)
rmuller's Avatar
http://www.expeditionexchange.com/disco2brakes/
An excellent write up on this.
Old 01-04-2006, 05:19 AM   #3 (permalink)
Roverhound's Avatar
Originally Posted by rmuller
Just don't buy from EE without some kind of lube.
The only thing you'll need that might be a little different is a 12 point 19mm socket. Also an impact driver if the phillips screw that holds the rotor in place is siezed.
As a matter of fact, it's a good idea, if you're going to work on your truck much, to get a set of 12 points in 1/4, 3/8 and 1/2 inch drives. LR seemed to like the 12 point bolt when they made these trucks.
It just doesn't matter.
Roverhound is online now   Reply With Quote
Old 01-04-2006, 08:54 AM   #4 (permalink)
Are you buying this truck from a dealer, if so have them do the brakes.
If not, how many miles on the truck, this will be a good indicator of rotor replacement.
Other then a impact driver for the philips screw, you don't really need any special tools.
Make sure you do a brake fluid flush so you can regain a firmer pedal.
Mike J.
Old 01-04-2006, 11:19 PM   #5 (permalink)
nice member
Mike J.
from father in law,46,000 miles on the truck. the rear pads have been replaced sometime back....not fronts. dealer said 3mm thickness left on front pads. don't know which rotors or pads to get. has 18" wheels,plan on oneday
to get 16" wheels, will i need to switch rotors when switching wheels
Old 01-04-2006, 11:32 PM   #6 (permalink)
Otherwise known as STEVE
oem rotors are cheaper and will work just like the original ones- nothing wrong with that at all. The DBA's are sexy, more money and should be used with kevlar pads. don't mix kevlar pads with stock type rotors though.
DBA's are blingy, but unless it's disposable income for giggles- I'd just do oem replacements. Lockheed/Delphi/Ferodo are oem suppliers.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 01-05-2006, 10:48 AM   #7 (permalink)
John,
That is strange, cause usually the front pads always go first, OH WELL.
If you don't feel any brake fade or shuttering when stopping hard, I wouldn't worry about the rotors, they are probably getting thin but OK.
As for going to 16" wheels later, this will have no effect on whatever pads and rotors you are using, they all take the same.
Make sure you get all new brake fluid for sure whatever you do.
Good luck,
Mike J.
Old 01-05-2006, 03:51 PM   #8 (permalink)
nice member
mike.. i totally agree= front pads go first,plus this truck never been offroad????
Old 01-05-2006, 03:58 PM   #9 (permalink)
nice member
.... Lockheed/Delphi/Ferodo are oem suppliers.[/quote] ,
are you talkn bout rotors, as i think i will use genuine rover pads, or should i
use recomended above brands thanks steve
Old 01-05-2006, 05:59 PM   #10 (permalink)
You can buy a lockheed/delphi pad in a lockheed/delphi box or you can buy the same pads that Land Rover bought from lockheed/delphi and put in their own box. Same pads, different price.
Rear brakes wear faster on DII's than on DI's because of the electronic brake force distribution that acts as an "anti-dive" mechanism to make braking less jarring to the body of the truck.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 G4 Disco
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1973 SIII 88
Old 01-05-2006, 06:03 PM   #11 (permalink)
nice member
thanks mud--good info on "anti-dive" mechanism
