Front Dome Light Issue - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 02-24-2009, 05:54 PM   #1 (permalink)
Ohio State Buckeye
4x4TANK's Avatar
Default Front Dome Light Issue
I've got a 99' series 2 disco and I have a weird issue. On the front dome light, the light will come on when the doors are opened, however not when switched to the on position. Its truly a pain when I have to open my door at 70mph on the highway to read directions. I am thinking the switch is bad, but let me know what you think.
Thanks,
Sean
4x4TANK is offline   Reply With Quote
Old 02-24-2009, 06:09 PM   #2 (permalink)
Reptile Expert
if you turn the switch to the full off position, will the lights not come on when you open the door?
04 D2
stolenheron is offline   Reply With Quote
Old 02-24-2009, 06:17 PM   #3 (permalink)
Ohio State Buckeye
4x4TANK's Avatar
When in the off position and the door open, it still doesn't come on, even though the other rear dome lights do. The only time the front dome light works is when the door is open,
Old 03-11-2009, 09:25 PM   #4 (permalink)
I have the same issue!!! When I want the front light on, I can't turn it on - only when the doors are open. On the flip side... I've been hooking up with a few women in my car late at night and had to wait for the damned rear light to turn off after closing the doors lol
SSFOX is offline   Reply With Quote
Old 03-23-2009, 06:56 PM   #5 (permalink)
Me too. I have experienced the same issue with the front dome light. I even purchased a replacement from the local Land Rover dealer. It was surprisingly inexpensive (under $15 if I recall correctly). The replacement is having the same issue.
FairfaxDiscoGuy is offline   Reply With Quote
Old 03-23-2009, 07:08 PM   #6 (permalink)
The Zebra
LandyII's Avatar
Gallery: 17
I can't think of a MORE uncomfortable truck to hook up in than the Land Rover Disco LMFAO
My Ride - 2002 Discovery II Kalahari Edition - Stock And Going To Stay That Way
LandyII is offline   Reply With Quote
Old 01-07-2013, 12:21 PM   #7 (permalink)
honda50r's Avatar
Did any of us figure this problem out? After my headliner replacement I ran into this one
-1998 Land Rover Discovery I, LE
-Not stock
"Don't Rover Over!"
honda50r is offline   Reply With Quote
Old 01-07-2013, 03:31 PM   #8 (permalink)
hafaday's Avatar
The only thing I can thing I can think of is, did you get the separate (on a d2, not sure on a d1) ground wire hooked back up to the metal plate behind the light? or possible, the grounding lug (on the light itself) was damaged on re-installation.
The ground lug on the light is held by a nut, that attaches to a metal plate behind the head liner. a ground wire attaches to the plate. if this makes any sense.
01 d2
Bill H.
hafaday is offline   Reply With Quote
Old 01-09-2013, 12:11 PM   #9 (permalink)
honda50r's Avatar
Yes, that ground is correct.. Unfortunately. Because you're right, it sounds like a ground issue. I'm starting to think switch issue
Sent from my iPhone using AutoGuide.com Free App
-Not stock
"Don't Rover Over!"
Front Drivers Parking Light In-op doc1911 Discovery Series I 9 11-06-2012 12:10 PM
Front Bumper Light Bar Installed built2crawl Discovery Series II 15 01-04-2007 11:00 AM
Ignition and rear seat dome light stays on CurryHook Discovery Series II 2 12-09-2006 11:01 AM
'99 DSII both front fog/driving light bulb plug melted Tnee Discovery Series I 3 11-24-2004 07:20 AM
SEO by vBSEO 3.3.2
