Old 05-01-2006, 09:50 AM   #1 (permalink)
drum655's Avatar
Default Front drive shaft check?
Is there a way to see if your front drive shaft joints are going bad without removing the shaft. I don't suspect mine are bad (i have no vibrations) but with all the talk i would like to know for sure!
2001 Disco II SE w/CDL
~Equipe 4x4 Winch Bumper
~Custom steel rear bumper
~Equipe 4x4 steering skid and radiator skid
~RTE rocksliders
~QT services front and rear diff guards
~2" RTE lift
~265/75 r16 Federal Couragia MTs
~Superwinch X9
~Safety Devices Roof Rack
drum655 is offline   Reply With Quote
Old 05-01-2006, 09:55 AM   #2 (permalink)
If you have over 50,000 miles on that double cardon, replace them cause the next warning you could get is your transmisson blowing up when that joint fails.
I changed my at just under 36,000 miles and of the 8 cups, 4 had turned the bearings to dust.
Get a kit from Bill at GBR or a set of Spicers plus the center ball.
Old 05-01-2006, 10:02 AM   #3 (permalink)
drum655's Avatar
how much will that set me back, and how easy is it?
~RTE rocksliders
~2" RTE lift
~Superwinch X9
Old 05-01-2006, 11:24 AM   #4 (permalink)
Rocky Mountain High
Funrover's Avatar
I know u-joints are easy.... I have not looked into a D2 yet..... You will be fine man!!
Old 05-01-2006, 02:08 PM   #5 (permalink)
For a good set of U-joints or the kit from Bill you are looking at $80 to $100. If you have never done a double cardon, pull off the drive shaft and have a local shop do the switch. They will probably charge you around an hours labor.
Old 05-01-2006, 03:45 PM   #6 (permalink)
guitar588's Avatar
hey mike how do i know if the previous owner hadnt changed the joints? whats a way i can tell
guitar588 is offline   Reply With Quote
Old 05-01-2006, 04:24 PM   #7 (permalink)
Take a look at the u-joints on the double cardon and see if they have grease jerks so they can be greased. If they do, someone has changed them and you are OK. Also add a grease jerk to both the drive shafte slip joints, they are predrilled from the factory and capped. Grease will allow the drive shaft to strech easier with out binding.
Old 05-01-2006, 06:14 PM   #8 (permalink)
Default lots of play up front
Mike,
On my D1, the front drive seems to have lots of play. Some posts I've read say some is normal, but I'm concerned. Can I tell if my U Joints need replacing on a D1 by checking to see if grease zerts are there? Also, is there an easy way to check the front differential...I'm wondering if the pinion gear is worn. Thanks.
Wade
wade is offline   Reply With Quote
Old 05-01-2006, 06:28 PM   #9 (permalink)
Originally Posted by wade
Mike,
Wade,
If it aint broke don't fix it. I wouldn't worry about your ring and pinion unless you see lots of metal in your diff oil.
Your front shaft didn't have a doble cardon so don't worry about that. When you say it is loose, do you have wiggle movement in one of the joints or does the drive shaft turn a little? If it turns a little, most likely OK and normal.
Old 05-01-2006, 07:31 PM   #10 (permalink)
Default I had a friend move from drive to reverse
Watching it, moving from drive to reverse, there is quite a bit of rotation. I can't move it with a screwdriver, but I'd say it is moving 12 degrees. If it is normal, I'm glad...the next warning is the transmission coming apart sort of unnerved me. Thanks.
Wade
Old 05-01-2006, 09:22 PM   #11 (permalink)
guitar588's Avatar
well i dont have experience on grease fittings and such, so could you run by me how they look, these grease jerks?
Old 05-02-2006, 03:32 AM   #12 (permalink)
Wheeler
SCSL's Avatar
They are like little protruding nipples, about 1/4" diameter. They will be on the shaft itself, as well as in each of the joints. You can buy a greasegun from any autoparts store - the fitting is universal. I suggest the type of grease labelled for use with marine trailers. It's highly water resistant.
Old 05-02-2006, 05:23 AM   #13 (permalink)
They're called "zerks", not "jerks". Greese jerks are those guys at quicky lube
Also, just because they have zerks doen't mean your u-joints are good, it just means they've been replaced at one time. To really know if they're good, you should remove the driveshaft and feel for free movement without excess play of the cardon joint. $00.02
O.B. is offline   Reply With Quote
