Old 08-13-2008, 08:35 AM   #1 (permalink)
boosoo's Avatar
Default Front End Issue 03 DII...wobble and pop
I have the dreaded wobble! 03 with 70k miles. Very pronounced when hitting bumps while at highway speeds. I just put a brand new OME steering stabilizer on. No help. Also noticed a "pop" when going very slow and making a sharp turn, either way. Any advice is appreciated. Thanks!
boosoo is offline   Reply With Quote
Old 08-13-2008, 04:12 PM   #2 (permalink)
Back in a Series LR after 25 years :-)
slouzon's Avatar
Wobble
Check you tie rod ends for free play.
Pop on sharp turns
Sounds like a CV joint
BTW since you have 70k miles you should make sure your front drive shaft is in good shape. If the u-joints are going bad that maybe your popping noise as well?
If that drive shaft comes apart while your driving you will be replacing your transmission after it beats big chunks out of it.
Steve
Back in a LR after 25 years!!!
71 Series IIa 88
01 D2
"BackInA88" on all the other LR forums
(Sign up here first and couldn't think of a good handle at the time! )
slouzon is offline   Reply With Quote
Old 08-13-2008, 06:22 PM   #3 (permalink)
mtnance's Avatar
Speaking of Front Drive Shaft rebuilds. (Which I'm aware should be done),...what is considered a fair price to have this done?
mtnance is offline   Reply With Quote
Old 08-13-2008, 09:29 PM   #4 (permalink)
2002 Discovery II SE
I just paid $225CDN to have the double cardon (which includes 2 u-joints and the centre shaft section) rebuilt. They also balanced it. That price included a $35 freight fee to get the u-joints to me in a timely fashion from the other side of the country.
2002 Discovery Series II SE. 2" OME Heavy Duty. 265/65R18 BF Goodrich All-Terrain T/A's.
I told my wife if the Land Rover goes, so do I. That shut her up.
Alak is offline   Reply With Quote
Old 08-13-2008, 09:31 PM   #5 (permalink)
If theres a pop, it could be a ball-joint. I just fixed one on a GM product that would be a clunk sound when turning right (only right) then clunk again once centered.
CV Joints usually make a continous click click click when turning. At least mostly in my experience.
Old 08-14-2008, 07:02 AM   #6 (permalink)
Check also that the pitman arm is tighly secured to the steering gearbox, and that the bolts that hold the radius arms are properly torqued at the axle and the chassis ends. Also check that the steering gearbox itself is properly torqued to the chassis.
tempestv8 is offline   Reply With Quote
Old 08-14-2008, 07:02 AM   #7 (permalink)
Are all the wheel nuts firmly on?
Old 08-14-2008, 07:22 AM   #8 (permalink)
boosoo's Avatar
Yes. The cheapest I've found in Dallas for replacing the U joints is $425. That sounds a little high. Some places quoted $600.
Old 08-14-2008, 08:13 AM   #9 (permalink)
got mud?
Jupiter Rover's Avatar
My wobble was because my M/T's were not balanced well enough. I just got them re-balanced and the Wobble is nearly gone. One more balance from the tire shop should do the trick.
DII
-- Pete
285/75 r16 Destination M/Ts
Jupiter Rover is online now   Reply With Quote
Old 08-14-2008, 09:42 AM   #10 (permalink)
slouzon's Avatar
WOW I think the Tom Woods shafts are only around $350.
Tom Woods Custom Drive Shafts Custom Driveshafts Specialist
I think the price is even cheaper than his website states as I believe he now has a drive shaft flange that does not require the flange adaptor?
Steve
71 Series IIa 88
01 D2
