» Sponsors
» Sponsors
Old 07-04-2009, 11:09 AM   #1 (permalink)
Default front pass door lock
Hey everyone, just thought i'd throw this on here first rather than ripping apart the door pannel.
so the problem is my front pass door will NOT unlock or lock via the key or interior button. the only way to open the door is to pull the inside handle(not such a smooth move on a date).
anyone know where i should start looking around?
thanks and happy late Canada day and fourth of July everyone
discomat is offline   Reply With Quote
Old 07-04-2009, 01:24 PM   #2 (permalink)
Super Moderator
Go and order either a new or used lock actuator then pull the door panel down once you get the replacement lock.
Old 07-04-2009, 01:50 PM   #3 (permalink)
I have the exact same problem (Same door even). I already have the new doorlock/latch assembly, just havent had time to put it in yet. I also just replaced my rear wiper motor, and broke almost half of the little red door panel clips, hope that doesn't happen on the front door too, I don't know where to get those stupid things!
Budget Monty is offline   Reply With Quote
Old 07-04-2009, 05:39 PM   #4 (permalink)
03 Disco SE7
mnfeo2's Avatar
HA! Just replaced mine this morning. Its not to bad just follow the Rave and it took about 3 hours.
Mike~
03 Disco2 (no ACE/SLS) - oh well, first LR
fixing her up
mnfeo2 is online now   Reply With Quote
Old 07-04-2009, 06:27 PM   #5 (permalink)
LoWBuDget RoVer's Avatar
Gallery: 10
where can i get the door actuators
Be Positive , Check my Youtube Profile: http://www.youtube.com/user/twowheelsnobrain
Rover almost 90% Fixed before I Sell it
Does anyone know of 12" subs under ($200 to $60)
LoWBuDget RoVer is offline   Reply With Quote
Old 07-05-2009, 05:21 PM   #6 (permalink)
I did mine yesterday. It took about an hour because I've never done one before. I had to take the bolt off of the bottom of the window guide rail (a 10mm bolt that is inside of the door and faces the back of the car if the door were to be shut), and the large torx bolt off that is on the back of the door (top of the door jamb area). And obviously the 3 torx bolts that actually hold the door latch in. Once the window frame was unbolted by those 2 bolts, I was able to flex the frame enough to get the lock out (It is tight, but it works). I first tried sliding the door latch down to get it out, but ended up having to slide it back up to its stock location, and rotate it out while flexing the window frame out a bit with the window up of course. Really not that bad. Just make sure you get the clear plastic vapor barrier back in correctly, you will get moisture in your car if you don't.
Here is where to get the door latch/lock assembly: Land Rover parts and Accessories, Range Rover parts part number: FQJ102900 Price: $124.50
I got mine used from a local truck getting parted out on Craigslist for $30. May want to see what used options you have.
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 22 11-10-2009 06:47 PM
TOO MUCH STUFF, Disco/RRC/Series/Defender/P38 GARAGE SALE RedRhinoProducts Land Rover Parts and Accessories 8 10-16-2006 10:41 PM
WTB Pass front doorlock actuator bajamanjc Land Rover Parts and Vehicles Wanted 2 10-06-2006 06:21 PM
Front Diff Searcaigh Discovery Series II 2 02-17-2006 04:26 PM
electrical box under front pass seat honybears Discovery Series I 7 10-17-2005 01:13 AM
