hi i have just bought a 1995 disco es i have 2 problems 1 is that when i change from 1st gear to 2nd going quite quick it grinds and wont go in,if i take it slow and easy it gos in fine,its worse when cold.people have told me they are all like this.also it has start useing alot of diesel like 30 miles to 10pound i have looked for leaks but cant find any.this is my first landrover so im new to it all if any one could help i would be most greatful.thanks all
2002 Discovery II SE
Correct me if Im wrong someone;
There are two basic kinds of manual transmissions. Syncromesh and non-syncromesh. 99.9% of all cars have a syncromesh. non-syncromesh transmissions are used in tractor trailers and other really really big trucks. When you push in the clutch and change gear, the syncro helps mesh the gears together properly without grinding it. This can only be accomplished properly by releasing the load/tourque on the tranmission. In other words, pushing in the clutch. On a non-syncromesh transmission, to change gear, you do not require the clutch. It can remain engaged, however, you are required to match the engine RPM to the speed of the transmission to change gear. This is also called rev match. You can do this on any transmission, although I dont recommend it on a new car. === What you are experiencing is the syncro has worn on 2nd gear. When you change fast, it wont go into gear because the syncro wont match speeds with the gears. When you change slow, it allows the worn syncro time to sync, or you are simply rev matching unknowingly. Most normal shifts rev match anyways. Can this be repaired? In short, it requires a transmission rebuild. Will it harm the transmissoin to drive with it? In short, the damage is done. Careful driving and transmission care and you can drive as much as you like. Recommendations: Check the oil level. Try an oil like Ams-Oil Redline, or other high end brand of oil. Make sure its the same weight as the old oil. |
Hi Wayneus 1
I can't tell you much about your gear problem as I drive an auto, but regarding your fuel consumption that sounds a bit excessive £10 per 30 miles, diesel is around £5 per gallon yes that’s rite 10 dollars a gallon here in the UK so your only getting 15 miles to the gallon. It sounds like your injectors need cleaning or at the very worst replacing, I would start with a fuel additive to clean the injectors and see if it improves your mileage. I drive an 03 TD5 and at the very worst in cold weather it has never dropped below 22 to the gallon doing short trips around town, on a run I’ll get 28 to the gallon, yours should be the same or even a little better running 4 cylinders and a manual gear box. Last edited by discofacelift : 01-09-2008 at 11:09 AM. |
| Thread Tools | |
| Display Modes | |
| Diesel Conversion-Thoughts? | AZROVER | General Land Rover Discussion | 26 | 07-11-2007 09:54 AM |
| Comments/Suggestions [Post Here] | rmuller | Tech & DIY | 29 | 04-20-2007 06:33 PM |
| Land Rover Frequently Asked Dumb Questions (very long...but funny) | JungleRR | General Land Rover Discussion | 0 | 05-26-2006 09:37 AM |
