Old 01-23-2008, 10:23 AM   #1 (permalink)
wayneus1's Avatar
Default gear change problen
hi all.when i change gear from 3rd to 2nd i get a whinning noise and you can feel it on the gear stick.its only when it is moving,if im stopped and change gear its ok plus its ok from 1st to 2nd,its just 3rd to 2nd.it does go in ok just get a whinning noise as you go into 2nd.any ideas thanks
wayneus1 is offline   Reply With Quote
Old 01-23-2008, 02:10 PM   #2 (permalink)
XtremeMarine's Avatar
That's the noise I got right before my internal clutch discs all blew in the tranny. First it was just one gear change, then two. Then all three. Bring it to someone who can read codes, and see if the tranny is throwing off any codes. I brought mine to AAmco, and they scanned it right there. Actually had a clutch code for the autobox.
Originally Posted by Elemental
Some guys play hard to get, I play hard to want.
Old 01-25-2008, 05:27 AM   #3 (permalink)
antichrist's Avatar
I had that noise in my Disco as the bakelite sleeve for the release bearing was spinning and shredding itself.
Tom Rowe
Atlanta, GA
62 88 reg
67 NADA x2
95 D1 - R380
95 D90 - R380
gear change and diesel problem wayneus1 Discovery Series II 4 01-09-2008 05:09 AM
gear change thumping noise 300tdi transmission andrew dunn Defender 3 11-10-2007 08:11 AM
Comments/Suggestions [Post Here] rmuller Tech & DIY 29 04-20-2007 06:33 PM
NYTimes: Is 8 Enough? Transmissions Meet the Need for Speeds Adam in NYC USA General Land Rover Discussion 6 09-16-2006 08:21 AM
Notchy gear change from 1st to 2nd gear mcguckiana Discovery Series II 1 11-02-2005 01:02 PM
