Old 03-05-2006, 10:43 PM   #1 (permalink)
BIRD's Avatar
Default Getting new brakes
I will be getting the brake kit special from Atlantic British. I was just wondering if anyone is using Ferodo Brakes. Any thoughts? Also how hard is it to change the rotors and such. Do I need any special tools?
BIRD is offline   Reply With Quote
Old 03-06-2006, 08:20 AM   #2 (permalink)
Otherwise known as STEVE
I like Ferodo pads- they work very well. What kind of rotors though?
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 03-06-2006, 08:54 AM   #3 (permalink)
Bird,
Those are good brake pads.
You shouldn't have any problem changing out the rotors, all you need is a hand held impact driver to remove the large phillips screw that holds the rotor to the hub.
By some aftermarket sound deadening material for the brake pads, Also, if the pads don't have a beveled edge, give them a slight bevel, both of thse will help keep any noise down.
Don't forget to flush your brake fluid.
Did it finally stop raining over there, how is your water leak doing?
Old 03-06-2006, 08:44 PM   #4 (permalink)
BIRD's Avatar
Disco Mike the rain stopped for a few days, but Wed they Say it will rain like hell again. As for the leak, I am still looking for it. I will try again tonight.
As for my brakes, I was going to order the whole brake kit. (PN: 9542F) It should come with all the small hardware that I will need. So how do I do a bevel on the brake pads? Do I have to spray them with any thing to keep them from squealing allot?
Old 03-06-2006, 09:05 PM   #5 (permalink)
Bird, some of the pads come with a slight bevel on the brake pad amterial ends, if they don't. any grinder will do the job, remember, just a slight vevel, not much is needed. Yes I would spray or goop some brake sound deaening material on them even if they come with a sound deadening pad.
It's a walk in the park.
Stay dry,
