Old 03-26-2008, 08:05 AM   #1 (permalink)
ultrrunr's Avatar
Default Ground strap
Can someone take a quick look out under your hood and tell me if the ground strap from the head is located on the RH (driver) or LH (pass) head to firewall? I just replaced my head gaskets and am wrapping up the minor stuff. I can't remember where it was located. I am thinking it technically and electrically shouldn't matter but I want it to be back the way it was. There is a threaded nut on firewall behind ignition pack and a stud with nut above and right of LH head....where is yours connected? Thanks.
ps - At least I remembered which head was on which side before I had them rebuilt.......
Micah
ultrrunr
"Life's Tough, it's even tougher if you're stupid." - John Wayne
ultrrunr is offline   Reply With Quote
Old 03-26-2008, 08:14 AM   #2 (permalink)
cboy's Avatar
the strap goes on the driver's side head. There are 3 holes back there, 1 to secure the harness, 1 for the ground strap and the last empty. The strap goes on a threaded stud on the bulkhead with a 10mm nut.
'66 109" Ambulance
'73 88" SW
'04 Discovery
'05 Range Rover
cboy is offline   Reply With Quote
Old 03-26-2008, 08:29 AM   #3 (permalink)
ultrrunr's Avatar
Thanks. Then nothing was mounted in the embedded nut behind the ignition pack, correct?
ultrrunr
Old 03-26-2008, 05:29 PM   #4 (permalink)
cboy's Avatar
Not sure what you mean. But there are a few empty holes. There was nothing attached tot he passenger side head and only those 2 things mentioned above on the driver side.
'66 109" Ambulance
'73 88" SW
'04 Discovery
'05 Range Rover
electric window issues - ground? hermanpj Range Rover Classic 3 01-22-2008 12:07 PM
Ground Anchor mudmonkey Accessories 14 01-22-2008 06:39 AM
Recovery strap rating AZROVER Accessories 6 02-21-2007 07:33 PM
Ground Points honybears Discovery Series I 2 11-19-2005 05:11 PM
I've fix it, here are the result $200 v $0 sidawson Discovery Series I 0 06-07-2005 10:46 AM
