Old 10-29-2005, 03:01 PM   #1 (permalink)
Unhappy Handbrake light flashes intermittently?
Hi there,
My Disco 2 has started flashing the handbrake warning light at me on an intermittent basis.
H/B operation is fine and light comes on with ignition and off when H/B put into off position, just blinks when stationary or under most road conditions.
Fluid level is fine in thre brake reservoir.
Any ideas, before I rip out the dash?
Thanks.
f5dougf5 is offline   Reply With Quote
Old 10-30-2005, 12:35 PM   #2 (permalink)
if the brakes are fine then perhaps the ebrake controls inside the drum are sticking.
Old 10-30-2005, 12:50 PM   #3 (permalink)
Rocky Mountain High
Funrover's Avatar
Check your wireing under the center console... In another car i had the positive wire was exposed and would periotically touch ground completeing the circuit
Old 10-30-2005, 01:50 PM   #4 (permalink)
Thanks. Will get out and get under
Old 10-30-2005, 01:51 PM   #5 (permalink)
frickjp's Avatar
Before you get dirty, pop the bonnet and unplug the reservoir float on the brake fluid. We've had a few sink.
frickjp is offline   Reply With Quote
Old 10-30-2005, 01:53 PM   #6 (permalink)
Thanks, will give that a go too. When you say centre console do you mean around the auto gearbox lever?
Old 10-30-2005, 01:53 PM   #7 (permalink)
You guys are full of ideas. Glad I joined.
Thanks.
Old 10-30-2005, 05:20 PM   #8 (permalink)
Default E-Brake Ligt
Your e-brake switch is either failing or out of adjustment. I don't there is any reason to worry about your flid level, that is another warning and there are no warning lights inside the e-brake drum.
Good luck,
Mike J.
Old 10-30-2005, 06:48 PM   #9 (permalink)
frickjp's Avatar
Originally Posted by Disco Mike
I don't there is any reason to worry about your flid level, that is another warning...
Incorrect. Red brake indicator on a D2 is for parking brake or fluid level.
Old 10-31-2005, 07:23 PM   #10 (permalink)
Default Hand Brake Warning Light.
You need to adjust or replace your e-brake switch which should be located in the console.
Mike J.
Old 10-31-2005, 08:47 PM   #11 (permalink)
Rocky Mountain High
Funrover's Avatar
yes...by the handbrake itself
Old 11-01-2005, 09:14 AM   #12 (permalink)
Thanks for all you help. Have a few ideas to persue this weekend.
Regards.
Old 11-03-2005, 04:24 AM   #13 (permalink)
TEAM GREEN
MY 2000 disco 2 had the same problem, i traced it down to the brake fluid switch / float assymble it had fliud in the float, i pulled the cap off the bottom of the float drained the fliud. put 422 loctite instant glue to seal it off that was 6 months ago it hasn't come on going down the road since.
MEEKROL is offline   Reply With Quote
