I have a 2001 discovery with 78000, The truck ran hot and the head gasket is shot i believe. My wife was driving and the temp light came on. She stopped and park the truck. I have found some coolant in the oil. Was planning on pulling the heads and have them rebuilt.
Should I have anything special done to the heads? What gasket kit should i buy and from who? I do not have a shop manual, is there anywhere i can download the instructions to start the work, would like to tear apart tomorow dont have time to wait for a manual. Is there anything else I should do while I have the heads off? |
How long did she drive it while it was hot? Quiet often when they overheat and you intermix the fluids, it can be caused by a dropped sleeve.
You will need to verify that first, as for the head, put a straight edge to them, I think the limit is .004, if they are warpped over that you will need to resurface and inspect for cracks, valves shouldn't need an work done on them. Go to Atlantic British or DAP and order one of the factory head gasket sets and a full set of new head bolts. Past that, change out the hoses and the t/stat, probably replace the serpentine belt if it is showing any wear as well as the belt tensioner and idler pulleys. As for instructions, find yourself a Rave CD with the shop manual on it, great way to go. Good luck, Mike |
Rebuilding Rover
pssssst here is a link to download any all the manuals you might need brother........
http://www.landrover.ee/est/varia/downloads/cars.htm ![]()
"Only two defining forces ever offered to die for you, Jesus Christ and the American G.I. One died for your soul, the other for your freedom." http://snhlr.org/ 91 Range Rover Classic 90 RRC Parts truck 94 Saab gas mileage beater
If, when she pulled over, she had let the engine idle with the heater on full hot so the engine would cool off, you would have a better shot at no engine damage. Unfortunately most people do what they think is the right thing, shutting the engine off and allowing it to get even hotter before it slowly starts to cool off.
Hope you luck out and don't loose the engine. Mike |
'99 Disco II
If you are doing this work yourself and you have a machine shop in mind already to do any machine work I would probably have the head and valves done. You have the engine apart...This is the time to take any variables out of the equation! Have the machinist check the heads and at least re-surface the heads. You will end up with a perfect surface to start with (for the head gasket and the manifold gasket). They will also clean the entire head inside and out so you will have no sludge, carbon, etc anywhere. They can lap the valves and have them seating perfectly. ask if they will check the exhast manifolds as well. You will already have them apart, so all you will need to do is unbolt three more bolts on each side ( i am pretty sure you can pull them right out without much trouble, just remember to get new deformed exhaust nuts and clean up the threads on the studs before you re-assemble)
As you can see, I am a proponent of doing more work while you are in there already. Good luck! this work is fairly inexpensive. Inquire about the price and check it out yourself. I think you may be pleasantly surprised!
'99 Disco II ACE / 2" OME lift 245 75 R16 Greatyear MT/R's
#9 (permalink) | |
Tom
http://greenoval.com/joomla/index.ph...d=13&Itemid=29
Tom --2001 Disco II SE - sold --2004 Disco II SE - work and play truck --2006 LR3 SE - wife's truck (play when she's not looking)
#10 (permalink) | |
#13 (permalink) | |
#14 (permalink) | |
#15 (permalink) |
Just got around to fixing the head gaskets. Heads just got back from the shop. Got head gasket kit from Dap. Do I need to use any gasket maker or adhesive or anything like that whren i am installing the gaskets. I got a new water pump, serpentine belt, plugs, wires and thermostat, anything else i should change while i am there.
