Head Gasket Replacement - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 01-24-2009, 08:26 PM   #1 (permalink)
Default Head Gasket Replacement
I am looking to tackle a head gasket replacement by myself and I am looking at what I need to purchase. I know I need the AB kit and replacement head bolts, but is there anything else I should purchase? or think about replacing while it is apart? My disco has about 58,000 miles on it.
Also, are there any special tools that I will need? Your advice would be greatly appreciated since I am a novice at working on my LR. Thanks.
hank222212 is offline   Reply With Quote
Old 01-25-2009, 05:54 AM   #2 (permalink)
Administrator
Just out of curiosity, why are you replacing the head gaskets? Based on your mileage you need to do a full 60K with wires at the same time alomg with a new t/stat and any hoses that are needed.
Old 01-25-2009, 06:23 AM   #3 (permalink)
Default head gasket
i have a contact for much less than AB, try <sales@autopost.demon.co.uk> ask to Paolo he will give you very fair price much less than AB and for sure same quality...for tooling...the "only" box set hard to find will be the 1/4 drive 8mm 12 points (12pt) box made for unscrew the oil covers make sure you have it for the rest of the job you need beers...have a good torque wrench and follow procedures into the Rave disk
martin hamel from Montreal
martin_hamel@yahoo.com
canadianDisco2owner is offline   Reply With Quote
Old 01-25-2009, 06:48 AM   #4 (permalink)
Originally Posted by Disco Mike View Post
Just out of curiosity, why are you replacing the head gaskets? Based on your mileage you need to do a full 60K with wires at the same time along with a new t/stat and any hoses that are needed.
I am leaking antifreeze out the back side of the cylinder heads. I originally thought it was just some hoses that were leaking, so I replaced those. They were leaking, but they weren't the only thing that was leaking. Turns out it was the head gasket. I took it into an indy that I trust and he showed me how it was leaking antifreeze out the back side. I don't feel like shelling out 2000 so I am going to attempt this on my own. No better way to learn than trial by fire!
I have a friend on stand by who is very handy in case I do too much damage.
Old 01-25-2009, 11:28 AM   #5 (permalink)
Do I need to buy the fan pulley wrench for the viscous fan removal? I see it is $120 at rovers north. Is this cheaper anywhere else if I need to buy it?
Old 01-25-2009, 12:09 PM   #6 (permalink)
you need a good wrench not a pulley for this fan..but 120$ is quite expensive
1999 4.6 needs some work; fix or sell? Spring Range Rover P38, Mk III and Range Rover Sport 22 11-10-2009 05:47 PM
Blown head gasket or slipped liner? deja7654 Discovery Series II 13 03-07-2009 09:48 PM
My head gasket is leaking v. Whats a good price? Grid_Lock Discovery Series II 4 05-28-2008 06:25 AM
Any experience with replacement of Head Gasket for a Disco II? TCampbell Accessories 4 05-08-2006 03:26 PM
K Series head gasket procedure freelanderman Freelander / LR2 5 04-20-2005 10:53 AM
Powered by vBulletin® Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
