Old 01-27-2007, 01:43 PM   #1 (permalink)
scotth's Avatar
Default headliner
Has anyone had to have their headliner replaced? I have 2 sunroofs and rear air and I was wondering what the cost would be. Are the headliners bad to fall because mine has not been wet but it is coming down in several places.
99 Disco 2
Kinversand ACE and SLS with 18's
brushguard and 265/60/18's installed
Hood blackout kit
RTE 2 inch lift
Future Mods:
TJM winch bumper,roofrack
scotth is offline   Reply With Quote
Old 01-27-2007, 03:19 PM   #2 (permalink)
Super Moderator
Disco's Avatar
Common complaint in earlier model Discovery's from around 95 onwards. The glue that holds the material to the main board becomes brittle with age and crumbles, and even if it doesn't get wet, air blowing in through your windows gets in underneath it and it begins to peel. 91 -94 models didn't seem to suffer the problem, that I'm aware of.
Old 03-09-2007, 02:50 AM   #3 (permalink)
HeadlinerExpress
HeadlinerExpress's Avatar
Headliner Express in Central Florida does all the Headliner & Sunroof Repair for
Several Landrover Dealerships in Florida for the last 13 years. On the series models you need to make sure the 60-62 inch width material is used to completely cover the corners as well it needs to be the 1/8th inch thickness as original not the 1/4 inch in which other shops use which is to thick and not wide enough. For those looking to tackle the job their self’s here is a link for the correct material that needs to be used. www.oldstock4less.Com
Headliner Express
Central Florida
68 Unimog TLF-8 Firetruck
65 Unimog Radio Box
www.HeadlinerExpress.com
www.LandroverHeadliner.com
HeadlinerExpress is offline   Reply With Quote
Old 03-09-2007, 04:10 AM   #4 (permalink)
Wheeler
SCSL's Avatar
Instead of replacing the sagging headliner in my DI, I'm thinking about taking it out entirely, taping the windows & edges, priming it, and spraying it with aerosol bedliner.... basically painting it, using this type of paint to give it a bit of texture. No more problems with sagging and a more utilitarian look & feel.
2001 DII - "Molly"
1995 DI - "Mary"
Old 03-09-2007, 05:05 AM   #5 (permalink)
HeadlinerExpress
That sound great, but keep in mind that bedliner paint does not expand and contract with the Heat & Cold and could cause more damage than good because of the build up of heat & Possible Fumes that could effect on your health over a long period of time. Another thought too is by removing the Board will make your series sound like a tin can. The Headliner Board act as a sound deadener ...Just a thought to consider.
Headliner Express
Central Florida
65 Unimog Radio Box
Old 03-09-2007, 05:41 AM   #6 (permalink)
Polish and proud of it.
TsiArt's Avatar
I just noticed the problem with my head liner yesterday , and i was going to ask the same question .
anyway . I'm pissed off cause every car i owned had.has head liner pealing .
I hate that shit .
Also looking at some pics , it looks like PITA to take it out .
I'm a Proud owner of a vehicle that has a turning Radius of 747
Check out our Frappr!
Myspace ? It dose not mather who votes, only matters who counts the votes _ Krushchew
TsiArt is offline   Reply With Quote
Old 03-09-2007, 05:53 AM   #7 (permalink)
HeadlinerExpress
I can walk you through the process if you would like, Since i do this for a living i can save you time on what to remove and not what to remove to get the best resolts, just let me know how i can be of help to you. Bill
Headliner Express
Central Florida
65 Unimog Radio Box
Old 03-11-2007, 04:36 AM   #8 (permalink)
I have a00td5 disco with the same problem. No sunroofs but still seems to be a p.i.a.to remove AND what do you do once removed.?
Can you remove and reglue of is that asking too much!.
Your imput is muchly reguarded Headlinerexpress.
cheers tracker
Tracker is offline   Reply With Quote
Old 03-14-2007, 03:40 PM   #9 (permalink)
anyone?
Old 03-14-2007, 06:59 PM   #10 (permalink)
HeadlinerExpress
Tracker- It takes me 3 hours to complete a series from start to finish. It will likely take you most of the day to do the same.
Removing the headliner Board will require a battery powered screw gun with a Philips bit, to remove the Visors, Visor Clips and Overhead console. The grab handles will need to be removed; sorry don’t remember off hand what size socket, but I can find it with no problem in my tool bag.
The Rear Quarter Panels located behind the Rear Seats to the Rear Swinging Door
Have plastic push clips that will best be removed with a door panel tool – “Claw type” to lift up the plastic flat heads to be removed.
You will also need to remove the “B” “Pillar Door Seal” in order to remove the “B” “Pillar Interior Trim Molding.” The Plastic B Post has 2 metal clasp that attach under the door seal and attach to the metal door lip.
If you have a rear seat belt that runs through the Rear Quarter panel you will use a 17mm socket to remove the bolt from the body located near the floor near the rear back door, once the seat belt has been removed feed the end through the rear quarter panel as you remove it from the body of the truck.
Leave the front seats in the upright position, and drop the backrest of the back seats forward.
Don’t forget the remove the rear dome light from the Rear Plastic Console just above the rear seats and disconnect the wire and remove the plastic cover that located next to the dome light that holds the fastening screw that holds the Headliner Board to the roof of the Car before dropping the headliner Board.
Remove the board ( you will be re-using the Board Only )
Remove and throw away the old Material with the foam backing no longer attached to the cloth is now garbage. Use a Nylon Brush and scrub down the Headliner Board to remove all the old foam back.
I have available on my web site enough material in the correct width and thickness to recover your existing board. www.HeadlinerExpress.com
If you still need more info just let me know.
Headliner Express
Central Florida
65 Unimog Radio Box
Old 03-15-2007, 02:29 AM   #11 (permalink)
Mate ,thank a million for that.It sure helps when someone explains the corrrectway to do it. Looks like sundays the day.
cheers Tracker
Old 03-17-2007, 11:25 AM   #12 (permalink)
DISCOY2K's Avatar
I've got a sagging headliner, and i've actually thought about doing exactly that, that way i'll never have problems with it sagging again
DISCOY2K is offline   Reply With Quote
