Heard Chirping Noise on my Disco II - Land Rover Forums : Land Rover and Range Rover Forum
post #1 of 24 (permalink) Old 11-17-2008, 07:19 AM Thread Starter
member
SafariDave's Avatar
Quoted: 28 Post(s)
Question Heard Chirping Noise on my Disco II
Heard a chirping noise last night that came and went. Took the car to the mechanic this morning we put it on a lift checked the drive shafts for play or looseness both Front & Rear and the u-joint on the transferC/tranny. They looked fine. I also discovered that my front drive shaft was replaced at some point with one that has nipples they were dry so we greased them up. Did not hear any chirping on my way home. What else can cause chirping. (we also checked the wheels).
The City is a Jungle.
2005 LR3/ SE 4.4 Fancy Professor (my girl's LR3)
2005 LR3/Disco3 SE 4.4 The Rhino
(mine)
De-tangoed Headlights, LR4 Style Grille, Dueler Alenza HL 255 55 19"
1999 LR Disco II SD 200,900 miles (Sold)
1991 Range Rover Classic (Sold) 'The Turtle'
1988 Range Rover Classic (Sold) 'The Rust Bucket'
SafariDave is online now
post #2 of 24 (permalink) Old 11-17-2008, 07:34 AM
Quoted: 0 Post(s)
Belts...the tensioner pulley can cause some noises...Brakes...hell I guess thats about all that comes to mine...I think the bearings in the alternator and a/c compressor can cause some chirping later in their lifetime...Could even be the blower motor...Hopefully its nothing more than lack of grease in the joints...
BamaDisco03 is offline
post #3 of 24 (permalink) Old 11-17-2008, 08:22 AM
Rover-Holic and Admin
ArmyRover's Avatar
Quoted: 37 Post(s)
Birds nest under the hood? Did the chirping sound hungry?
Make sure to grease those uj's at least everytime you change the oil. Double check to make sure there are no slop in them after being run dry. It's better and cheaper to do the uj's than the tranny.
1972 MGB
2007 Chawton White LR3
Trident Green, 1983 110
Need new parts, genuine Land Rover, aftermarket and off road upgrades, Support the Vendor that supports the Land Rover Community
716-898-8153
Want a
best read this first
Need used parts?
ArmyRover is online now
post #4 of 24 (permalink) Old 11-17-2008, 08:28 AM
Administrator
Quoted: 5 Post(s)
I always get a kick out of it when someone says they crawled under and determine their u-joints "LOOK" OK.
If you don't have grease fittings on all 3 front u-joints, "LOOKS" won't cut it.
Disco Mike is offline
post #5 of 24 (permalink) Old 11-17-2008, 09:15 AM
Beach Bum
Quoted: 0 Post(s)
Ditto, the only time you 'might' be able to see a damaged u-joint will be right before they fail - - - AKA, BANG!
brian4d is offline
post #6 of 24 (permalink) Old 11-17-2008, 09:21 AM
ArmyRover's Avatar
Quoted: 37 Post(s)
I have seen failed uj's before they let go. More often then not though it's a complete inspection that has saved my butt.
1972 MGB
716-898-8153
Want a
Need used parts?
post #7 of 24 (permalink) Old 11-17-2008, 09:35 AM Thread Starter
member
SafariDave's Avatar
Quoted: 28 Post(s)
Where is the 3rd grease fitting in the front drive shaft or U joint?
(mine)
post #8 of 24 (permalink) Old 11-17-2008, 09:44 AM
ArmyRover's Avatar
Quoted: 37 Post(s)
If it's like mine there is one on the shaft and one on each joint this is on a RRC so your mileage may vary
1972 MGB
716-898-8153
Want a
Need used parts?
post #9 of 24 (permalink) Old 11-18-2008, 08:47 AM
This Isn't My Boyfriend's Truck!
AnnelieseMae's Avatar
Quoted: 0 Post(s)
My front drive shaft sounded like a bird chirping...turned out that my u-joints were about to go! Got it just in time...after my u-joints were replaced, the birds were gone.
I was really lucky...it started chirping while I was on a road trip...it got really bad once I returned home. Super lucky!
New owner of a mostly stock Disco II, 50k.
I will be asking a lot of questions...please excuse my ignorance!
AnnelieseMae is offline
post #10 of 24 (permalink) Old 11-18-2008, 09:16 AM
Beach Bum
Quoted: 0 Post(s)
You are VERY Lucky. How many people had no warning at all before the big bang theory?
brian4d is offline
post #11 of 24 (permalink) Old 11-18-2008, 10:01 AM
Rocky Mountain High
Funrover's Avatar
Quoted: 0 Post(s)
Yeah my parents where pulling their camper with their P38.. started to chirp on a steep uphill.. I am glad we found before damage happened!
Funrover is offline
post #12 of 24 (permalink) Old 11-18-2008, 10:08 AM Thread Starter
member
SafariDave's Avatar
Quoted: 28 Post(s)
Now does this chirping come and go or you always hear it.
(mine)
post #13 of 24 (permalink) Old 11-18-2008, 10:29 AM
Beach Bum
Quoted: 0 Post(s)
I expect it depends on how much grease has cooked out of the u-joint, meaning how much grease is left in the u-joint depends on the amount of chirping. In theory....
brian4d is offline
post #14 of 24 (permalink) Old 11-18-2008, 11:08 AM Thread Starter
member
SafariDave's Avatar
Quoted: 28 Post(s)
Had my land rover mechanic drive it around he says he knows this sound well. He has fixed plenty of them. He drove it and we did not hear it. Later when I drove off I heard a bit for like 3 sec then it was gone. No vibration, nothing. I'm having an alighment done on monday. I'll have him re-check it. (both front U-joints were greased yesterday nipple type). Also we have so many noisy trucks in NYC and pot holes, are streets and highways are the worst in the USA. In NYC Sometimes you hear a noise you think its your Rover and it's a truck, van, car, bus or taxi a few feet from you. They all squeal or have noises it's confusing. If not they cover it up with loud music.
(mine)
post #15 of 24 (permalink) Old 11-18-2008, 01:51 PM
Quoted: 0 Post(s)
FYI...in my case...the chirping came and went while I was on the road. Once I got back from my road trip, within two days the chirping was constant, every time I got in to drive.
Man...that was close!!!
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Linear Mode Linear Mode
Strange Engine Noise 2004 Disco SE7 nashville rookie Discovery Series II 4 08-21-2008 05:12 AM
Anyone heard of RR sport s/c engines in a disco? stolenheron Hybrid 6 09-25-2007 09:29 AM
Rattling/Grinding Noise in 2004 Disco G4... bernardmann Discovery Series II 11 02-11-2007 07:40 PM
Noise from Disco II 2000discoII Discovery Series II 9 02-11-2006 03:12 PM
2002 Disco TD5 "suspect" noise in Power Steering Robbo Discovery Series II 1 06-19-2005 01:11 AM
You may post new threads
You may post replies
