I have a question for those utilizing the Heated Front Windshield on DII models.
My front windshield is not heating up properly. I would like to know how many of you are using it and how long does the button stay on when you select the winshield to heat? It only stays on for about 5 minutes, is this normal? The rear-defroster seems to be working fine and it stays turned on until I select it to turn it off. I took my DII to local LR Dealer in Buffalo, NY and they said that Front Windshield is working fine but I don't believe them. I have extended warranty from LR dealer and I don't think they want to repair it. Thanks, Hugo |
#2 (permalink) | |
Roads?...Where we're going, we don't need roads...
![]() Join Date: Oct 2005
Ive got an 01' DII and that sounds about right.....something like 5 mins. Its normal, not broken. |
Thanks Guys, I wasn't sure that there was a time limitation. This helps me isolate my next problem.
I will take it back to LR again. The driver's side windshield area is not defrosting properly. I keep getting un-defrosted areas in my windshield. Thanks again, Hugo |
I have the heated windshield in the Range Rover. Again, it shuts off after 5 minutes (read owners manual). The way it operates is half of the defrosting lines operate first, then the other half operate last. The windshield takes lots of power, that's why it does it this way. It tends to be a little erratic in the way it operates, sometimes not defrosting everything. I just push the button again. The windshield in the Range Rover has been replaced 4 times due to stone chips, so I know how it operates when its brand-new.
Current: 2005 Land Rover LR3 V8 SE 2000 Land Rover Discovery II SD 1992 Land Rover Range Rover County Also current: 1995 Mercedes-Benz E320 Wagon 2002 Volkswagen Eurovan GLS 1996 Ford Explorer LTD 2WD 1982 Volvo 240 GL Diesel Previous Rover: 1995 Range Rover 4.0SE |
| Thread Tools | |
| Display Modes | |
