Old 06-27-2005, 05:12 AM   #1 (permalink)
Post Heated Seats
I am led to believe that many UK Discos 2 have heated seat pads fitted although not wired up to the switchs as on higher spec models.
Can anyone throw light on this and how to find out if pads are in place?
Don Halpin
Don Halpin is offline   Reply With Quote
Old 06-27-2005, 09:26 AM   #2 (permalink)
John's Avatar
Try searching LRO as I seem to remember an earlier discussion confirming what you have said
John is offline   Reply With Quote
Old 06-27-2005, 10:04 AM   #3 (permalink)
John's Avatar
Here, I found it for you, click on this:
http://landroversonly.com/forums/sho...t=heated+seats
Old 06-30-2005, 04:17 AM   #4 (permalink)
Default heated seats
John,
Many thanks, seems worth fitting switches to find out.
Don
Old 09-15-2005, 04:52 PM   #5 (permalink)
ChuckD's Avatar
Default Heated Seats
I pulled the switch panel and found the two (green & black) plugs just hanging there. I did a resistance check and there is some... meaning that the pads are most certainly there. I have ordered the switches and will post results next week when they are installed. I'm very hopeful that this is a $50 way to get heated seats!!
Chuck
ChuckD is offline   Reply With Quote
Old 09-16-2005, 03:31 PM   #6 (permalink)
ChuckD's Avatar
It worked!! The switches were easy to install and the seats get warm. They only get to about 80 degrees, and it takes a while, but this is better than paying $600 or so. I got switches and cover plate from Atlantic British.
