Old 05-19-2006, 05:14 AM   #16 (permalink)
Underwater hockey is no dumber than any other sport
Roverdude's Avatar
I put heated seats in my SE3 freelander. Like steve said, it's not hard, but a bit of a PITA. The FL is pre-wired for heated seats and that's it. I had to install the heater element, switches, and modules. I don't think the Discos require the modules. The switches are pretty straightforward, plug and play. The modules also plug in and snap into the seat frame. The elements are tricky, but just remove the seat from the truck, and take your time. It's not that difficult once you figure out how they're assembled.
"Guinnevere" '91 RR
'08 LR2 SE
'05 MINI Cooper Convertible
Roverdude is offline   Reply With Quote
Old 05-20-2006, 11:50 AM   #17 (permalink)
guitar588's Avatar
Originally Posted by Muddy Oval
If it's an S or SD model, it's not leather. The SE and HSE had leather.
i dont really know what i have since its a '99. its like a mix between an sd and se. because i dont have woodgrain, the harmon/kardon system, or heated/power seats, but i do have sunroofs and ace. any ideas?
guitar588 is offline   Reply With Quote
Old 05-20-2006, 12:43 PM   #18 (permalink)
A 99 will have seat heaters if you have leather, mine did.
You mentioned ACE, how do you like it, and even more importantly, have you ever serviced it, makes a hugh difference in how they run.
Old 05-20-2006, 01:13 PM   #19 (permalink)
Otherwise known as STEVE
Most people can't tell the difference between the fake leather and real leather seats.
Another way to tell if it has the heater elements is to see if the plugs under the seats are connected to anything.
2002 Freelander
2000 DII w/CDL
1967 SIIA 109SW
Former Rovers
2004 Modded "S" Disco, R.I.P.
2004 G4 Disco
2002 Modded Freelander
1995 Modded Disco
1994 D-90 #8
1993 NAS D110
1990 Range Rover County
1973 SIII 88
1972 Range Rover 2 door
Old 05-21-2006, 01:26 PM   #20 (permalink)
guitar588's Avatar
i havent serviced the ace yet, i dont really know how to, it works fine but sometimes ill make a tight turn at the bottom of a hill for example and itll moan, i dont know if thats normal. truck has 59k. any suggestions?
Old 05-21-2006, 06:47 PM   #21 (permalink)
Time to change the oil. PM me with your e-mail or telephone # and I'll walk you thru it, takes 20 minutes, will save you about $140 over what the dealer will charge, assumong they know how to do it, most don't.
