Old 01-11-2006, 08:39 PM   #1 (permalink)
Default Hello and questions
This is a very nice site you guys have here. I have lurked a bit. I have a 2000 discovery2 which now has 67000 miles. I have had it for 2 years now and love it.
Recently I have the christmas tree of lights known as the ABS, TC, and Down hill Decent lights glowing on my instrument cluster. I am not overy concerned after reading some posts. Has anyone fixed this with out going to a dealer? I am sure the computer could be reset by removing the negative power cable from the battery. I just don't believe in letting the dealerships screw up stuff I can fix.
My other question is have any of you experiened the valve covers leaking oil? It seemed to me that it is a little early for them to do that, but then again I am a rotary engine guy.
Thanks in advance for all the help.
Brad
Rotary Inspired is offline   Reply With Quote
Old 01-11-2006, 09:10 PM   #2 (permalink)
The guy with the Banhammer
keptin's Avatar
Hmm....not sure about the valve covers but as for the ABS, etc. lights....its probably more then pulling the negative off your batt....hehe, I tried that.
Mine was a less common problem where bad jolting (hehe....racing off road) threw a code that made my ECU think I was on air suspension, but it couldnt find it. It took bringing it to an independent shop and using Testbook to change the code [back to the one with coil springs] from my understanding.
A common thing is that one of your wheel sensors has failed or is dirty or something.....comes down to $90 and some time replacing the sensor after your find out what wheel the problem is on.
by the way...welcome!
Josh Shapiro
DII
Old 01-11-2006, 09:51 PM   #3 (permalink)
Rocky Mountain High
Funrover's Avatar
Welcome man!
Old 01-12-2006, 04:46 AM   #4 (permalink)
Forward!
Badger1's Avatar
Gallery: 1
The valve covers leaked on my wifes 2000 D2 also(66000miles). I just retorqued the valve covers back to OE specs and everything is good to go, no leaks...and that was a good 6000 miles ago.
Old 01-12-2006, 10:20 AM   #5 (permalink)
The oil leak from the v/c gaskets is somewhat normal, tightening them tends to crack the gasket causing a bigger leak. if they are not dripping on the exhaust or drive way don't worry about it, that is just part of a Rovers thing.
As for the lights, there is no way to turn off the light except using a a proper scanner like Rovers Test Book. Everything else will just cause you frustration and some problems.
Mike J.
Old 01-12-2006, 08:22 PM   #6 (permalink)
Thanks for the info guys.
