Old 11-06-2006, 06:48 AM   #1 (permalink)
drum655's Avatar
Default help
EVAP system leak large. what can i do to remedy this? Mike, this seems like a question for you.
2001 Disco II SE w/CDL
~Equipe 4x4 Winch Bumper
~Custom steel rear bumper
~Equipe 4x4 steering skid and radiator skid
~RTE rocksliders
~QT services front and rear diff guards
~2" RTE lift
~265/75 r16 Federal Couragia MTs
~Superwinch X9
~Safety Devices Roof Rack
drum655 is online now   Reply With Quote
Old 11-06-2006, 07:13 AM   #2 (permalink)
Have you checked your fuel cap for a pressure loose? Othere then that, the only thing it could be, I believe, would be a small crack in one of the fuel hoses near the tank. Your are venting off pressure so the leak is not going to be fuel but air pressure.
Hope tis helps.
Old 11-06-2006, 08:20 AM   #3 (permalink)
drum655's Avatar
i have checked my fuel cap and it seems fine. is there any way for me to check and know for sure? and how can i check the fuel lines?
~RTE rocksliders
~2" RTE lift
~Superwinch X9
Old 11-06-2006, 11:33 AM   #4 (permalink)
Some shops and the dealerw will have a testing device to check your cap, as for the hoses, you are just going to have to crawl under the truck and inspect all the line, migh even want to pull the inspection plate for the fuel pump and look thru there .
Good luck,
Old 11-06-2006, 11:35 AM   #5 (permalink)
drum655's Avatar
does that require me lowering the fuel tank? could it be my purge valve?
~RTE rocksliders
~2" RTE lift
~Superwinch X9
Old 11-06-2006, 11:59 AM   #6 (permalink)
bama's Avatar
we have a smoke machine at our shop!! what do you think mike? can i use it on drums disco?? if so get it to me and we will take a look at it here for ya, no problem at all.
bama is offline   Reply With Quote
Old 11-06-2006, 12:01 PM   #7 (permalink)
drum655's Avatar
free....bama....and then in trade, i will take you on some trails!!!!
~RTE rocksliders
~2" RTE lift
~Superwinch X9
Old 11-06-2006, 12:05 PM   #8 (permalink)
bama's Avatar
sounds good to me!, that will be awesome my tech said we can look at it for ya!
Old 11-06-2006, 12:07 PM   #9 (permalink)
Smoke works well, actually a good idea, let me know how it goes.
Old 11-06-2006, 01:01 PM   #10 (permalink)
drum655's Avatar
Bama, can i swing it by tomorrow after work? if so what time...i get off about 1 tomorrow...let me know...thanks for the hook up
~RTE rocksliders
~2" RTE lift
~Superwinch X9
Old 11-06-2006, 01:05 PM   #11 (permalink)
bama's Avatar
no problem at all man, thats what we do i think tom. at 1pm should be fine we i hope we can handle it for ya! be nice to meet ya any how!
Old 11-06-2006, 01:10 PM   #12 (permalink)
drum655's Avatar
it will prolly take me almost an hour to get there so plan on seeing me at about 2....where is the shop located?
~RTE rocksliders
~2" RTE lift
~Superwinch X9
Old 11-06-2006, 01:48 PM   #13 (permalink)
bama's Avatar
Georgia 400 north to exit 7b holcomb bridge rd. Regal Nissan, where are you coming from??
Old 11-06-2006, 01:53 PM   #14 (permalink)
drum655's Avatar
I live in the downtown area, but i work in Clayton County so it will be a good little drive for me after work. But i can prolly be there by 2 or so. That is so cool that you are doing this for free for me! when do you wanna go trail riding?
~RTE rocksliders
~2" RTE lift
~Superwinch X9
Old 11-06-2006, 02:01 PM   #15 (permalink)
bama's Avatar
whenever is good with me, i work this saturday until 5pm but am off every other weekend. no thanks needed at all! its nice to be able to try and help and also i might learn something!!! i got some guys up here that wheel quit often but me Im a newbie. Question know of any good trails and camp sites?? Glad to be able to help you guys
