Old 05-22-2008, 05:19 PM   #16 (permalink)
Codylar's Avatar
Gallery: 10
Default Update
Well, Dealer checked plugs, wires, coils and compression in #6 all are good. No extrenal leaks can be seen. No oil in water or in cycle #6 .When misfire happens it happens at start up and not everytime. Dealer says no more ideas on extrenal fix problem must be intrenal. He told me sleeve slight dropped causeing misfire due to fluid sepping into cyclinder. I still think its that head gasket they replaced 6,000 miles ago giving me problems and they won't say that due to the fact they are the ones who put it on. Any thoughts
Codylar is offline   Reply With Quote
Old 05-23-2008, 08:42 AM   #17 (permalink)
KDamericano's Avatar
slipped liner just seems like such a stretch in that situation. I'd definitely get a second opinion.
KDamericano is offline   Reply With Quote
Old 05-23-2008, 09:44 AM   #18 (permalink)
Rebuilding Rover
ArmyRover's Avatar
agreed. Head gasket again maybe but a slipped liner seems like a long shot to me.
http://snhlr.org/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Old 05-23-2008, 08:39 PM   #19 (permalink)
Codylar's Avatar
Gallery: 10
Well I took it to an independt rover mech. he said that same thing slip sleeve in #6, misfire happens on start due to fuild in cyclinder. He said probably slight slip so only a small amount goes into block after sitting overnight. The pressure good and that is what keeps more fluid going into sleeve while driving. He said exhaust can get forced into the block if the vehicle operates like that. He said can't be head gasket because that the water is routed @ #6 so the chance is small that it could be that. What do you think. This is not sounding good on my end.
"Then there are sheepdogs," he went on, "and I'm a sheepdog. I live to protect the flock and confront the wolf." Semper Fi
2001 SE DISCO 2IN OME
Old 05-23-2008, 08:46 PM   #20 (permalink)
polar's Avatar
Well if it is a liner issue, then you are looking at a short block. I guess some one might beable to fix the liner and reline it or something. I would look for a short block with some kind of warranty.
2002 Discovery 4.0 55K
Delo 400 5W-40 synthetic
CI-4 PLUS, CI-4, CH-4, SL (SAE 5W-40)
Zinc=1310
Phosphorus=1560
polar is offline   Reply With Quote
Old 05-23-2008, 11:42 PM   #21 (permalink)
Codylar's Avatar
Gallery: 10
You guessed it, they said shortblock etc. $7,500 and I am back in bizness. Yeah, woo hoo
Old 05-24-2008, 09:20 AM   #22 (permalink)
2002 Discovery II SE
Theres a shop here that does 4.6L swaps into DII's. The guy said its the same price as the 4.0L and it directly bolts in using alot of the 4.0L stuff.
Something to think about if you decide to fork over all those sheckles.
Alak is offline   Reply With Quote
