Help with Disco II sunroof - Land Rover Forums : Land Rover and Range Rover Forum
» Auto Insurance
» Featured Product
Old 01-25-2013, 06:35 PM   #1 (permalink)
Default Help with Disco II sunroof
So the sunroof on my '03 discovery no longer works and was looking for help. When I press the buttons for the front or the back sunroofs nothing happens, no motor or anything and was wondering if anyone knows if there is a set way to reset or if it is possible the fuse may have gone since neither work (I live in the northeast & its cold out so i never checked prior). Also, my battery died on me about 3-4 weeks ago if that could have anything to do with it. Any suggestions on this would be great.
Thanks guys!
wrestler197 is offline   Reply With Quote
Old 02-19-2013, 05:32 AM   #2 (permalink)
HeadlinerExpress
HeadlinerExpress's Avatar
1)you will need to check the electrical system with a wire tester to determine if current is getting to the sunroof motors or switches
2)with age the sunroof motors do need to be taken out and taken apart and cleaned as all the electrical parts corrode because all the moister that is associated with your sunroof.
3)Both of your sunroofs are the same so while testing you can switch the front sunroof motor “switch” with the back sunroof and get the same response.
It’s a process of Elimination to find the problem it’s not likely it’s just as simple as a fuse
Feel free to ask any question . Bill
Headliner Express
Headliner & Sunroof Repair
Winter Park, Florida USA
68 Unimog TLF-8 Firetruck
65 Unimog Radio Box
98 Range Rover 4.6 (Sold)
www.HeadlinerExpress.com
www.LandroverHeadliner.com
HeadlinerExpress is offline   Reply With Quote
Old 02-19-2013, 07:20 AM   #3 (permalink)
Administrator
First as a side issue, go to your local parts store and have your charging system test, they usually do it for free, voltage should be between 13.6 and 14.4.
As for the sun roofs, go check your fuses.
Need Parts?
paulgrant@mac.com or call 203-770-1699
willtillery@roverguy.com or call 434-251-9331
P.T. Schram 260-804-0458
Lucky8, http://lucky8llc.com/
British Parts of Utah, http://www.bputah.com/
Old 02-19-2013, 08:08 AM   #4 (permalink)
My vote the sunroof motor
Blamo is offline   Reply With Quote
Old 02-19-2013, 08:31 AM   #5 (permalink)
Administrator
Bad guess, both of his sun roofs are in-op, 2 separate motors.
Need Parts?
Old 02-20-2013, 07:39 AM   #6 (permalink)
No, good guess, because it's entirely possible that both motors could have failed.
Source: Both of my motors have failed due to water infiltration.
Hamal T.
1994 Range Rover County LWB - Sold for Parts
1999 Disco II, 98k, Stock
1999 Kawasaki Ninja ZX-6E - Summer ride to work.
1994 Ford Taurus SHO - Modded Q Ship.
Racer X is offline   Reply With Quote
Old 02-20-2013, 09:26 AM   #7 (permalink)
Administrator
Chances are pretty slim at best.
Need Parts?
Old 02-22-2013, 07:45 AM   #8 (permalink)
04DII
At the same time??? Possible, but not likely.
Start with the fuse, then get out a mulitmeter; check for wiring continuity or a ground short from fuse to switches, then check switches for voltage on the output side when switch is engaged, then the same at the motor(s). Somebody probably tried to open a sunroof when the thing was frozen shut, and blew a fuse.
TCollier is offline   Reply With Quote
Help with Disco Sunroof! wrestler197 Accessories 2 02-19-2013 05:11 AM
Disco I Sunroof Install? losinov Accessories 12 11-07-2010 04:25 PM
Sunroof Leak?? Disco II SE7 MimiKim General Land Rover Discussion 1 02-03-2010 03:55 AM
95 Disco rear sunroof nodia21 Discovery Series I 7 10-29-2008 08:09 PM
Leaking rear sunroof in 97 Disco BeattyD Discovery Series I 1 01-25-2005 07:17 PM
SEO by vBSEO 3.3.2
