Old 04-01-2008, 03:31 PM   #1 (permalink)
Unhappy Help! Doors won't open
I broke the fob for my 99' disco 2 about a month ago. Since then I've been locking and unlocking the doors by using the key hole on the driver side. Yesterday I locked the doors as usual but when I tried to unlock them none of the doors unlocked except the driver door. I tried unlocking them with switch on the dash and they still won't unlock. Does anyone have any idea what the problem is? My sons are currently climbing over seats.
Thanks!
hattix007 is offline   Reply With Quote
Old 04-03-2008, 08:11 AM   #2 (permalink)
New Yawker in California
RudemanRB's Avatar
Gallery: 1
this might sound silly but try disconnecting your battery for 30 seconds. and reconnect it. then see if that works.
Rudy
RudemanRB is offline   Reply With Quote
Old 04-03-2008, 08:45 AM   #3 (permalink)
Before you broke your remote, did your remote unlock all 5 doors at the same time or did you have to push the unlock button twice?
Try unlocking the door 2 times and see if the second turn of the key opens the rest of the doors.
Old 04-05-2008, 06:48 PM   #4 (permalink)
Phlawed's Avatar
My D2 has started doing the same thing. I have not tried the battery trick yet, but mine started with drivers door. It has to be locked and unlocked with key. The rest of the doors would lock and unlock from remoke key. But, now my rear drivers side door has to be manually locked and unlocked by the door handle and pushing down the lock. Hope its not contageous.
2000 Land Rover Disco II
1969 Ford Mustang (under resto)
Phlawed is offline   Reply With Quote
Old 04-05-2008, 06:56 PM   #5 (permalink)
you will need a new door latch on the door.
Old 04-15-2008, 03:40 PM   #6 (permalink)
Sorry for the delayed response I was out of town. Thanks for the advice guys. Rovin4life you're right the dealership says I need a new door latch. Anyone have any idea what this should cost to replace or if this job is doable for a semi mechanically inclined newbie?
Old 04-15-2008, 06:11 PM   #7 (permalink)
Good place for a guaranteed used latch is, Doors - Door Latches
Cleveland National Forest To Host Motorized Route Inventory Open House jmeyert4a West Coast - USA 0 01-17-2008 09:21 AM
interior light dont come on with doors open?? RoverRick Range Rover Classic 0 12-26-2007 12:28 PM
New owner can't open front doors from outside. atikovi Discovery Series I 8 04-11-2007 07:45 AM
obd two codes Rovin4life Discovery Series I 4 12-25-2006 10:16 AM
0BD 2 code list Rovin4life Range Rover P38, Mk III and Range Rover Sport 1 12-19-2006 07:43 PM
