I have spent a bunch of time searching for the answer and have had no luck.
My rear HVAC is not working and I believe it is because the relay is missing. I had to replace the two relays under the glovebox to get the front HVAC to work and noticed there are a few wires hanging loose. Is the relay for the rear system located in the same spot under the glovebox or do I need to look else where? A picture of the location would be super helpful. I picked this Rover up in a junkyard and have had a lot of fun putting it back together but this is really starting to aggravate me.
Thank you for any help.
JD Bayer
JD Bayer
