Hello forum contributors
,I need a little help on how to modify my 2002 Discovery for basic off-road use. I have been reading the forum for help but the information I need has been in tid-bits here and there and now I need to put it all together. The off-roading this Disco will need to be equipped for is the following: I own a small ranch in the Gila Region of New Mexico to get to my place I need to cross and re-cross a small desert river 5 times maximum depth of wading is 16-18 inches anything deeper, the velocity is much too fast and water too muddy to see rearranged boulders to cross in any vehicle sanely. ( I know as my main ranch vehicle is a 91 dodge diesel 4x4 7,000 lbs of truck) The angle of approach coming out of the river is very steep and muddy so I need to get rid of the stock front bumper. Often I go up-river at night so I need lights to see through the water for the differential smashing rocks. Thats it higher clearance (31 -32 inch tyres), steep angle of approach and vision perhaps a differential lock would be good for going up the steep muddy banks. I want to keep this simple and clean as possible as I still need to drive this Disco as my daily drive. Maybe I can keep this modification around $6K Here is where I need the help: New slim profile front bumper (have my eye on RTE love their recovery tabs) but winch or no winch? ( would need different springs with winch?) I have never gotten the dodge tank stuck in the river but have had trouble getting traction coming up out of the river??? Suspension lift This is where I really need help please - Will heavy-duty springs (RTE) and OME shocks allow me to put 32 inch tyres on 16 inch wheels??? Do I need lift spacer blocks? Or wheel spacers?? Do in need longer brake line sections for a 2 inch lift??? LR 16 inch wheels cost twice what others cost are they better?? Skid plates and differential guards and rock sliders I am for all of these any tips??? Lights Seems easier to install on light bar on top of new bumper. How many? What kind? My nephew says I need them on roof top to see in the inky midnight water. Please help me here??? Differential lock as much as I really love the home made levers I have seen in the forum the only time I would need to regularly use it I would be in the middle of a flowing river as locking the differential should only be brief yes ??? help me out here please. So I think a solenoid is for my use? Carrying a Highlift jack will the door that now carries spare tyre hold the additional weight of a highlift??? I know this is long just help briefly where you can - If I have not thought of anything please let me know! Thanks in advance and if any body hunts elk!!! I know one of the best areas of the country contact me I really appreciate all the help I can get. ![]() |
#2 (permalink) | ||||||
4 Hella 4000s on my roof rack.. Cornerning Beams on the outside, Euro Beams on the inside.. and 2 Hella 4000s Fogs on my front bumper. Quote:
Hopefully that gives you some good direction.. I must have the Christmas Spirit today to type all that out ![]()
#4 (permalink) | |
03 DII- S w/CDL, lifted, armored and beaten on- Beasley 90 RRC- stock and babied- Brutus Classicus |
#7 (permalink) | |
Your wading depth on a standard Discovery Two is 19.7 inches.
If you want to go higher then buy a Snorkel Why waste money on a lift. you loose always going high. Also too you can buy offroad tires in 18 inches. Michelin Synchros are the best. Nitto grapler are ok but not thick enough sidewall. With a steep and muddy terrain I would recommend putting on a diff guard and the Two bumpers mentioned. But before you buy all the goodies. Test drive the Discovery in its native environment. The one it was built for. You might find yourself pleasantly surprised that the Discovery Two lacks very little.
#9 (permalink) | |
As for lift.. what do you lose by going high? 2" lift will gain you clearance for larger tires, which will get your diff higher off the ground.. will also lift the body up higher, increasing your maximum wading depth.. and give you more articulation if you drop a tire down into a rut. With a 2" lift, there is generally no worry about driveline angles changing such as the driveshafts.
#10 (permalink) |
for "basic" off-road use...I think a stock DII will do just fine...you'll be surprised.
I'd say get the recovery gears first.
2002 Discovery II SE 1999 Range Rover P38 HSE |
#11 (permalink) | |
Wheeler
- 20" tow strap (a legit one, not the kind w/ built-in hooks) Many supporting vendors for this type of gear. - Tow hitch/receiver shackle, plus an extra shackle, pair of work gloves - Hi-Lift jack and base (home made base is fine, but drill a hole either way and tie about a 5' piece of rope thru it so you don't lose it in mud) plus a Hi-Lift winching kit - breaker bar & socket for lug nuts - stock size BFG A/T tires, or siped BFG M/Ts - tool bag with all the expected tools plus a metric & standard socket set - spares bag with assorted fuses, a spare rotoflex, electrical tape, duct tape, motor mounts, block of wood approx 2"x8" or thereabouts, tire repair kit - fluids box with motor oil, gear oil, atf, coolant, brake fluid, etc Sounds like a lot but it's not really. Your first upgrade, after tires, should be xfer case. Not only will a center-locking diff provide obvious benefits off-road, it will help you greatly in the event of trail damages such as a blown driveshaft, u-joint, roto, axle (unlikely in stock config), etc. I would also strongly suggest rock sliders as you first "armor" upgrade. I've always suggest sliders & diff guards before bumpers. (Hopefully not too far before..) |
