Can someone confirm for me if the condenser fan is on all the time when the A/C is on or if it only comes on when the computer tells it to....i just replaced the fan motor [because it was seized] and the fan still does not run with the a/c on....fuse is good...compressor is running.
Used a test light to check for power at the fan connection with the a/c on...nothing...tested it bridged [test light accross the connection] and no power...the funny thing is the fan ran [at a slow speed] for a couple seconds when i started the truck with the A/c on then it shut off...fan is free....any ideas???? hopefully my manual gets here soon so i can figure this stuff out...later, Dean |
Cuda,
Without tech data available,I just went outside to my truck to verify the fan operation: outside air temperature was 62 degrees, I started my truck and turned the A/C to max cold, no fan! So I'm assuming the A/C operation is thermostaticly controlled throught the computer just like the back-up fan operation is. Maybe drive your truck around with the A/C on and see if it comes on after the truck gets warm. Hope this helps |
Cuda, just a thought but one of the two fans on our Volkswagen stopped working, and the problem was a big resistor which supplies power to the fan. I think our DII also has a resistor for the fan. Check it out--for the VW, the part was about $50.
Current: 2005 Land Rover LR3 V8 SE 2000 Land Rover Discovery II SD 1992 Land Rover Range Rover County Also current: 1995 Mercedes-Benz E320 Wagon 2002 Volkswagen Eurovan GLS 1996 Ford Explorer LTD 2WD 1982 Volvo 240 GL Diesel Previous Rover: 1995 Range Rover 4.0SE |
The cooling fans are supposed to run anytime the A/C is on, or when the engine reaches a specific temperature (temperature switch), including after the vehicle is turned off. (from my memory reading about it) I just replaced both of mine (97 Disco) and they both run when the A/C is on...unfortunately all the time in Texas. If it is a Disco close to my year model, there is a relay on the passenger side footwell (assuming you are not in Europe).
Oops. Mine is a D1. For the DII, see below: Electric cooling fan switching points: For A/C system: On When vehicle speed is 50 mph (80 km/h) or less and ambient temperature is 28 °C (82 °F) or more Off When vehicle speed increases to (62.5 mph (100 km/h) or ambient temperature decreases to 25 °C (77 °F) For engine cooling during normal running: On 100 °C (212 °F) Off 94.5 °C (202 °F) For engine cooling at ignition off (to counteract heat soak): On If, within 10 seconds of ignition off, intake air temperature is 60 °C (140 °F) or more and engine coolant temperature is 110 °C (230 °F) or more Off After 10 minutes or if engine coolant temperature decreases to 100 °C (212 °F) Hope that helps you.
Wade Location: Texas |
