Old 04-28-2008, 09:12 PM   #1 (permalink)
jmrivera's Avatar
Default HELP! Need to ID these wires...
Hi all,
For my '03 Disco HSE7, I purchased the LR trailer harness... It only has 5 wires coming out of the harness that is hidden behind the tail lamp... Can anyone help me identify the remaining wires that are not being used? What I really want to find out is where the other ends of these wires are located in the front of the vehicle and whether or not I can use these wires for a brake controller and a trailer battery charge line... This is the information I have so far...
On the Disco harness side; LR trailer connector side; function (see second image below)
black; white; ground
green w/purple stripe; red; brake lights
green w/white stripe; green; right turn signal
green w/black stripe; black; tail lights
green w/red stripe; yellow; left turn signal
unknown wire function on the Disco harness side (see first image below):
red w/yellow stripe
green w/brown stripe
purple
red w/orange stripe
I know that the LR3 has a commercially availably connector that will allow for a brake controller to plug into a harness located underneath the dash, near the center console... Does the Disco have this?
Any help would be greatly appreciated... In the end, if I must, I will just run wires for the brake controller and the trailer battery charge line, but I want to avoid that if necessary...
Thanks,
Jonathan
jmrivera is offline   Reply With Quote
Old 04-28-2008, 10:03 PM   #2 (permalink)
nzoliver's Avatar
Gallery: 5
Howdy!
You will find that 1 is rear fog lights and 1 is reverse. And, I'll bet 1 is switched or full time power.
nzoliver is offline   Reply With Quote
Changing to Magnecor wires mudmonkey Discovery Series II 5 02-03-2008 12:47 PM
I finally replaced my plugs and wires wimp Discovery Series II 10 03-09-2007 11:36 AM
Misfire, Coil or wires? BlueDisco Discovery Series II 4 02-09-2007 08:53 AM
OEM trailer harness???? extra wires??? 6cuda6 Discovery Series II 4 07-13-2006 05:02 PM
Those *&$% spark plug wires 2000discoII Discovery Series II 6 03-18-2006 06:14 AM
