Old 06-18-2008, 08:36 AM   #1 (permalink)
Lady Rover's Avatar
Question Help PLease!
A little tech info, if you would.
2000 Disc 2. Are GEM & Bosc 4.0 engines interchangable?
Lady Rover is offline   Reply With Quote
Old 06-18-2008, 09:58 AM   #2 (permalink)
Elemental's Avatar
Yes, with slight modifications.
Old 06-18-2008, 10:02 AM   #3 (permalink)
What are you trying to do???
jmrivera is offline   Reply With Quote
Old 06-18-2008, 12:42 PM   #4 (permalink)
Why are you asking, is your Bosch engine in trouble.
Gems are old engines that can be swapped but only by parts, not an entire engine. They completely different management systems.
Old 06-19-2008, 08:41 AM   #5 (permalink)
Lady Rover's Avatar
Yup, nearest dealer is over 100 miles and NOT user friendly. Especially for a female who is at least moderately auto savy. Do all my own minor repairs. Have dealt with other engines, this is my first Rover adventure.
Have a lead on identical engine with fewer miles(decent warrenty-trustworhty yard). Less $ than dealer wants for gasket and head. Any headaches I might expect in advance?
Old 06-19-2008, 08:44 AM   #6 (permalink)
So what problems are you having??? Major or minor?
Old 06-20-2008, 04:53 PM   #7 (permalink)
Lady Rover's Avatar
Lots of water in the oil, not a good thing!
Old 06-20-2008, 05:17 PM   #8 (permalink)
KDamericano's Avatar
Unless you dropped a sleeve, you should just need a head gasket repair. No sense in buying a whole new engine if that's all that's wrong. Was it severely overheated? The differences in the two engines are listed here
Buick 215 Rover 3.5 Land Rover 4.0 and 4.6 differences
KDamericano is offline   Reply With Quote
Old 06-25-2008, 11:32 AM   #9 (permalink)
Lady Rover's Avatar
Never Overheated - Learned a long time age to shut it down before guage goes much above normal and call a ramp truck. Never made red zone!
Old 06-26-2008, 06:33 AM   #10 (permalink)
The Basic Difference Between The 4.0 And 4.0 Bosch Is The Crank Sensor Mount. Pretty Easy To Swap. Grind Off The Spot Welds Clean Everthing And Jb Weld It Back In. It Uses A Roll Pin To Align It .
roverhouse is offline   Reply With Quote
