Old 06-17-2005, 04:57 PM   #1 (permalink)
Exclamation Help with removing center console
Help!
I'm in the process of a CDL linkage modification on my Disco II and I can't figure how to get the gear shift assembly out of the way to remove my center console.
Does the shifter knob just screw off the shifter-rod, or does the rod screw off of the mechanical bellcrank? or am I doing it all wrong to start with?
O.B. is offline   Reply With Quote
Old 06-17-2005, 05:11 PM   #2 (permalink)
O.B...if you are trying to remove the trans shift knob...then do this
grab ahold of it real firm like...and...PULL directly upwards..
It's a real pia, but thats how its done.
good luck
son of lucas is offline   Reply With Quote
Old 06-17-2005, 05:14 PM   #3 (permalink)
That's what I needed , THANKS!
