Old 06-25-2008, 11:27 AM   #1 (permalink)
Default Hi. Just bought a Disco 2. Got a CeL.
Just wanted to say hey to everbody as a new member of the forums and rover owner. I just bought a 99 Discover 2 se7 with 69k miles and pretty much all the bells and wistles for $5500. I love the new ride and cant wait for the full "multipurpose vehicle" experience.
About 300 miles after buying it, it threw a check engine light and the people at autozone said it was throwing the light for running too lean - although ill have to go back and get the exact code. Ive been running premium gas in it and was wondering where I should begin to look for the problem?
Eclipsed013 is offline   Reply With Quote
Old 06-25-2008, 11:33 AM   #2 (permalink)
Go to your local auto parts store, get the codes read and get back to us with them today so we can help you.
Old 06-25-2008, 11:52 AM   #3 (permalink)
p0171 - lean bank 1
p0174 - lean bank 2
p1668 ?
thanks
Old 06-25-2008, 12:33 PM   #4 (permalink)
First two are common lean codes usually caused by a bad MAF, check and sse what you have for an air filter, is it dirty, is it a K&N filter?
Most likely going to need a new MAF.
Old 06-25-2008, 12:55 PM   #5 (permalink)
Its a white accordian style filter with an orange edge holding it together. It doesnt have a brand name of any kind on it, but its fairly clean. Minimal trash in the filter box. How hard is it to get the whole assembly out?
Old 06-25-2008, 01:47 PM   #6 (permalink)
Standard filter, that's good. As for the junk, pull the filter out and shake out some of the junk, if it looks old and real dirty then wipe the junk out of the box and replace the filter.
Safe to say you will need a new MAF.
Shout if you can't find then for under $200 and I will point you in the right direction.
Old 06-25-2008, 02:09 PM   #7 (permalink)
I hit the inside of the filter and the box with a shop vac and it got most of the dirt out. Im gonna run to the store shortly and pick up a couple replacement paper air filters. Ive got a few links for a new maf from searching around on the forums, ill take a closer look at em shortly. But if you have a cheap source in mind i would love to save some cash.
Old 06-25-2008, 02:35 PM   #8 (permalink)
Call Tony at Cerrones, 650-365-4145 for what I believe will be the lowest price.
Old 06-25-2008, 04:06 PM   #9 (permalink)
Steph's Avatar
Since you seem to be heading for a new maf, try taking the maf out, and clean with Q-tips sprayed with non chlorinated brake cleaner. worked for me. Worst case scenario, it won't work and you'll need a new maf, which you're already getting ready to buy.
FYI, to take the maf off, I used vise grips, since the torx bolts have a tit in the middle and calls for specific tool.
Knowledge is only really worth anything when its been experienced first hand. If you heard it from a guy who heard it from a guy.....nevermind and keep it to yourself.
Steph is offline   Reply With Quote
Old 06-25-2008, 05:00 PM   #10 (permalink)
'00 DII Member
auwesman's Avatar
wow that worked? I've tried to play the "clean the MAF" game, and it just got annoying (would work a few months, then not, then work a day, then not, then a few weeks then not................................uhhhhgggg)
Anyhow, I'm suprised that worked for you. Most people that try to clean the thing wind up killing it.
'00 DII
'07 Toyota Taco
War Eagle!
auwesman is offline   Reply With Quote
Old 06-26-2008, 06:17 AM   #11 (permalink)
Not a wise move with a D2, Bosch MAF, this will normally kill them. A older style D1 MAF can sometimes be cleaned, but by using a good quality electronic contact cleaner, not carb spray that will leave a residue.
Old 06-26-2008, 06:26 AM   #12 (permalink)
brian4d's Avatar
Default Just reading
Like Steph said, he's gona buy a new one, why not give it a shot? I know I need a new starter, but why wouldn't I hit it with a hammer to get another 1 - 2,000 miles out of it?
brian4d is offline   Reply With Quote
Old 06-26-2008, 07:20 AM   #13 (permalink)
Steph's Avatar
Thanks Brian
Just bought a 04 Disco. What would you do? Sweig337 Discovery Series II 9 05-30-2008 05:03 PM
Just bought a 95 Disco... questions requesting answers KO-SALES-TEAM New Member Introductions 9 03-08-2008 05:56 PM
Bought a Disco II SuperSickWitIt Discovery Series II 6 08-11-2006 08:06 AM
Hello! I just bought a 98 Disco! San Diego. Brokenneckj West Coast - USA 12 03-09-2006 10:26 AM
For those of you that bought a Disco recently Carlos Discovery Series I 7 03-12-2005 01:54 PM
