Old 09-16-2007, 08:20 PM   #1 (permalink)
Default HID Upgrade for 03' Disco??
Is there safe functioning HID upgrade for the 03-04 Disco headlights? I see that Bosch makes some but wanted to hear what you all thought. Thanks!
Discoandaboat is offline   Reply With Quote
Old 09-17-2007, 01:54 AM   #2 (permalink)
Ian Matthews
p76rangie's Avatar
Do you really want to go to HID. Found that IPF "X" series globes put out nearly as good as light as HID, but cheaper and can still use a standard globe if the globe dies.
Old 09-17-2007, 10:32 AM   #3 (permalink)
are you talking about drop-in's or a kit that turns your standard lights into projectors?
I have been looking for some pictures of stock cut off with HID's dropped in... i have had no luck. The cut off from the beam pattern is really clean right now and seems like it would stay that way even with HID's but i have a 2000 not an 03. Best of luck ill let you know if i find anything.
Scott
scottagnew101 is online now   Reply With Quote
Old 09-17-2007, 12:46 PM   #4 (permalink)
I just want a clearer brighter headlight... any suggestions?
Old 09-17-2007, 01:02 PM   #5 (permalink)
If you just want regular bulbs that are clearer and brighter, I've got SilverStar's in mine..
Get the "brightest" ones..
They are alot better than stock bulbs fo' sho!
2003 Land Rover SE7
- Stock Hardon Karmon speakers
- Stock Navigation System
- Cold Weather Package
- SLS
- ACE
johnnybob06 is offline   Reply With Quote
Old 09-17-2007, 03:27 PM   #6 (permalink)
Ian Matthews
p76rangie's Avatar
IPF "X" series globes make silverstarrs look like candles, but they are more expensive that Silverstars.
For replacing a H4 type globe, the IPF X51 "fat boys" are excellent. They give a brighter light on low beam compared to high beam. It is low beam that you spend most of your time on.
They come in the various frequency colours. I have had the blue/white type higher frequency type globes and hated them, now I stick to things in the 3,000 to 4,000 range.
Old 09-17-2007, 06:03 PM   #7 (permalink)
Rebuilding Rover
ArmyRover's Avatar
I put the 6k in my wifes ML320 and my motorcycle and have really liked the improvement. It's a lot brighter cleaner light easy installation on the kits I purchased. I plan on upgrading the lights on the RRC in the very near future
http://www.wheelinrovers.com/
91 Range Rover Classic
90 RRC Parts truck
94 Saab gas mileage beater
Old 09-17-2007, 06:10 PM   #8 (permalink)
KevinNY's Avatar
X2 on the Silverstars
"The Goat",1973 Series III coil conversion, Daihatsu 2.8 Td, power steering, dual ARBs Etc.
'91 RRC, bone stock
KevinNY is offline   Reply With Quote
Old 09-17-2007, 06:32 PM   #9 (permalink)
Kevin,
Can you send me some pics of your 04' Lifted. Thanks!
You can send them to ryebread211@yahoo.com
Old 09-17-2007, 07:05 PM   #10 (permalink)
Rebuilding Rover
ArmyRover's Avatar
I thought I had before and after with the HID upgrade on the bike and I did so here are a couple of pics
Before
After
90 RRC Parts truck
Old 09-17-2007, 11:05 PM   #11 (permalink)
wow!!.. those bike pics look sweet!!
What kind of bulbs were those??
Has anyone done a projector retrofit on a Disco?? I bet that would look freakin' sweet!!!
I'm tryin' to find them, but I cant.. :[
2003 Land Rover SE7
- SLS
- ACE
Old 09-18-2007, 06:44 AM   #12 (permalink)
Rebuilding Rover
ArmyRover's Avatar
It's a kit by Xentech. H4 bulbs 6k spectrum the difference is quite literally night and day. Took me about 2 hours to convert and that was because it was a bike. Not alot of useable space for the ballasts to mount up. The ML320 only took 30 min or so.
90 RRC Parts truck
Old 09-18-2007, 09:10 AM   #13 (permalink)
+1 to ArmyRover, nice!!!
I've been looking for a projector kit that looks factory and not rice (not to diss, just not my thing) and can't find anything. I'd read nothing but great things about the SilverStars on other car forums but had factory HIDs so never tried them till I got the Rover. For the $40, I felt like they were a waste. The light is def cleaner but I don't feel much better than a factory bulb and really not a substitute for Xenon. Maybe I got a bad set given everything else I've read but if you are really looking for Xenon performance I'd go with a kit.
I want a top quality kit and have been a bit skeptical of what I have seen so far. I was thinking of getting the factory RR ballasts and then just getting H7 xenon bulbs. Has anyone gone this way with success?
tee51397 is offline   Reply With Quote
Old 09-18-2007, 12:18 PM   #14 (permalink)
if you want to know about HID please ask, i completly cut up my last set when i did custom headlights on my last VW GTI. I'm pretty sure i just about killed myself doing this.
The only bad thing about doing drop in's is the light cut off. Next time you see an acura or just about any of the new rovers with projectors look at the beam when it hits the car behind it or a wall. It will look flat on the bottom left then a slight upward angle then level back off. This is so it does not blind other drivers.
Now Acura has been putting HID's behind non projector housing with great sucess in the TL models prior to the new body style. So im not sure if the cutoff that the DII has now would remain the same or if it would become very blurry, this is very important as so it does not look as if you have your brights on all the time.
However, one thing that most people think about with HID's is heat, and the fact that it wont work behind plastic. This is false. They produce much less heat than a conventional bulb and will not melt plastic as long as your regular bulbs do not. One good thing is that HID's last MUCH longer then the regular bulbs, hence the high price. (around 40-60% longer)
If you have any questions (tech. or general) about HID's i will do my best to inform you. For what its worth i plan on doing this down the road, i just dont have time or money right now.
Old 09-18-2007, 12:36 PM   #15 (permalink)
rmuller's Avatar
http://muddyoval.com/forum/viewtopic.php?t=3408
