Old 04-17-2008, 11:40 AM   #1 (permalink)
MikeChiro01's Avatar
Default High Pitch Whine at 70 MPH
Man thank goodness for message boards.
Ok so I've had my 03 disco SE for about 6 weeks.
I've noticed there is a high pitch whine that happens around 70 MPH that goes away when I let off the accelerator.
Also when I'm decelerating off the freeway and the transmission is down shifting there is a loud "clunk" around 20-30 MPH.
It sounds like its coming from the front of the car and not the rear.
Any suggestions as to where to start my diagnosis?
FYI the first thing I did when I got the car is have the driveline rebuilt with greasable u-joints. That solved the vibration problem.
MikeChiro01 is offline   Reply With Quote
Old 04-17-2008, 12:23 PM   #2 (permalink)
Crawl under the truck, check the 2 u-joints that hook the front shaft to the t/case, if there are no grease fitting on these joints, get them replaced ASAP, before they fail and take out your tranny.
Old 04-17-2008, 12:26 PM   #3 (permalink)
Had the shaft rebuilt 4 weeks ago.
Old 04-17-2008, 12:46 PM   #4 (permalink)
When did you last have your t/case serviced or the fluid level checked?
Rovers are know for a little whine, might consider switching to an 85W/140 gear oil, sure quieted mine down.
Old 04-17-2008, 12:49 PM   #5 (permalink)
Yeah I saw some of your posts regarding the oil.
I actually don't know the service history of the vehicle so a fluid change was going to be my next step.
Would that explain the clunking during downshifting?
Old 04-17-2008, 01:46 PM   #6 (permalink)
When you had the 2 u-joints replaced, did they grease the others including the 2 slip shafts? What sort of shape is your roto flex in, any cracking?
A little lash is normal in the drive train, if this is a new vehicle for you, it may be normal or not, hard to say.
Old 04-17-2008, 01:54 PM   #7 (permalink)
Yea they used castrol synthetic grease, they balanced it too.
Actually I'm replacing the rear pinion oil seal this weekend and had a rotoflex inspection on the list.
I'll try a heavier oil too as you suggest as this car seems to have been someones daily driver.
Judging from the apparent lack of service to the common problems Disco II's have my guess is that with 75k on the odo this person didnt want to fix anything and got rid of it. His loss my gain.
Old 04-17-2008, 03:06 PM   #8 (permalink)
Might want to try the Royal Purple gear oil, buy 7 quarts and do the diffs and t/case. Make sure to inspect the magnetic plugs from the diff, fine metal shavings are fine, bits and pieces aren't.
Old 04-17-2008, 03:46 PM   #9 (permalink)
thanks I'll update after this weekend
High Pitch Sound under Hard Acceleration/High Speed Run msport Range Rover Classic 88 06-26-2007 07:53 PM
High pitch whine at 70mph.... Discoandaboat Discovery Series II 3 05-18-2007 04:40 PM
[All] Pre 96 OBD1 Fault Codes TerryS Tech & DIY 0 01-26-2007 08:00 AM
obd two codes Rovin4life Discovery Series I 4 12-25-2006 10:16 AM
0BD 2 code list Rovin4life Range Rover P38, Mk III and Range Rover Sport 1 12-19-2006 07:43 PM
