Old 09-23-2007, 07:51 PM   #1 (permalink)
Default hmm... need some answers
Couple things for ya'll..
1.) Is there any way to change out the hinges on the rear passenger doors so they open wider? I mean, the opening is small enough, but LR could have at least made hinges that open the door more fully!
2.) How much are belt tensioner and/pulleys because I'm getting that chirping noise when the A/C is on.
3. I was looking at the amazing suspension system that these things have and I noticed on the right wheel well, towards the front of the truck, that I've got a shock there, but on the left side, there is nothing there.
4.)My braking really sucks!.. I've heard about different rotors and brake pads ya'll have used... which are the best and how much would they cost to buy AND install?
Just a couple things that I would like answered!
Thanks!!
2003 Land Rover SE7
- Stock Hardon Karmon speakers
- Stock Navigation System
- Cold Weather Package
- SLS
- ACE
johnnybob06 is offline   Reply With Quote
Old 09-23-2007, 08:11 PM   #2 (permalink)
Call me tomorrow .
303-862-7680
Old 09-23-2007, 09:36 PM   #3 (permalink)
'00 DII Member
auwesman's Avatar
I've got Akebono pads. Under $200.00 for the set, no brake dust! It's been great. Change them yourself and save a ton of money. I believe I heard the last brake change someone paid for cost over $800.00! Process is SIMPLE!
Are you sure its your pads and roters that are bad? A lot of things can cause bad brakes. I'd check and see how much wear you have on your current pads and roters.
'00 DII
'07 Toyota Taco
War Eagle!
auwesman is offline   Reply With Quote
Old 09-24-2007, 05:55 AM   #4 (permalink)
Brakes....
Def go with DBA Slotted/drilled rotors with the Kevlar pads. Disco Mike recommended them to me and they are great. It stops a Disco like an M3.
It did them with a friend who knew what he was doing, but I called around and they are approx $80 per wheel to do. Good luck, that all the answers I got@
Discoandaboat is offline   Reply With Quote
Old 09-24-2007, 09:08 AM   #5 (permalink)
2004 Discovery II driver
hmm where did yall get your DBA slotted/drilled rotors and the Akebono pads (no brake dust sounds lovely!)?
stolenheron is online now   Reply With Quote
Old 09-24-2007, 09:17 AM   #6 (permalink)
Wonderful!
You all are amazing!
now, could anyone give me any insight about the other issues??
Thanks again!!
John-Robert
2003 Land Rover SE7
- SLS
- ACE
Old 09-24-2007, 10:46 AM   #7 (permalink)
Steph's Avatar
The shock thing is your ACE attachment. It only hooks on the pass. side. As for the door, I'm also curious about that, but I think we'll have to live with it
Steph is offline   Reply With Quote
Old 09-24-2007, 03:11 PM   #8 (permalink)
'00 DII Member
auwesman's Avatar
As for the belt tension, when was the belt changed last? I've never had a belt chirp on my rover, but it did on my old ranger and a quick belt swap cured that.
I got my akebono pads from Tony over on LRRForums. I can't locate his # right now, but I'm pretty sure DiscoMike has it.
'00 DII
'07 Toyota Taco
War Eagle!
Old 09-24-2007, 11:12 PM   #9 (permalink)
Hey!
My belt was replaced at 30,000 miles.. I currently have 48,XXX miles... and I've had the vehicle since 33,000 miles.
I bought it at the beginning of January.
Thanks!!
2003 Land Rover SE7
- SLS
- ACE
