Old 04-15-2006, 04:22 PM   #1 (permalink)
Default Hood switch.
I was just changing my air filter and noticed the little switch right next to it didn't have any wires going to it, I saw the wires laying down below the switch, It had an orange/purple and black wire. However, i could not get the plug to go into the switch???? What is the function of this switch? I'm assuming it's something to do with the alarm.
99 disco ii w/ cold climate and SLS.
plastic is offline   Reply With Quote
Old 04-15-2006, 04:26 PM   #2 (permalink)
It is the hood switch for the alarm. Without it your alarm should not set, unless someone cross wired it.
Is your alarlm working?
Old 04-15-2006, 11:21 PM   #3 (permalink)
As far as I know it works. What's the easiest way to set it off?
Old 04-15-2006, 11:38 PM   #4 (permalink)
The guy with the Banhammer
keptin's Avatar
throw a brick through the window?
hehe....probably locking it with the remote, then trying to open the door using the key.
Josh Shapiro
DII
Old 04-16-2006, 06:25 AM   #5 (permalink)
I know the alarm arms itself, cause the red light starts blinking.
I guess I don't understand why i couldn't get the plug to go back into the switch. It was the only plug laying around in that area. the shape of it looked compatible. So, a bit of a mystery to me.
Old 04-16-2006, 08:24 AM   #6 (permalink)
As far as I know, the alarm should not set if the switch is unplugged. Are you the originial owner? I keep thinking someone must have unplugged it cause the switch broke or was acting up, and they tied a couple of wires together to complete the circuit.
Old 04-16-2006, 08:32 AM   #7 (permalink)
no, i'm not the original owner. I guess i'll just forget that i found it. hehe
Old 04-16-2006, 09:20 AM   #8 (permalink)
Many times people unhook these switchs cause they will fail and cause problems. In your case, it doesn't seem to be causing a problem and I would leave well enoung alone. The only down side for you, if someone tried top poop the hood to steel something, the alarm won't sound.
