Old 07-03-2008, 12:22 PM   #1 (permalink)
Default How to check your radios ground wire?
hey guys,
does anyone know th procedure/process for checking your radios ground wire to ensure that it is secreulry grounded? do i need to remove head unit? (if so how do i do that? and will i need secrity code to get it to work again?) thanks for any help you cna give! -nick
nick731 is offline   Reply With Quote
Old 07-03-2008, 01:21 PM   #2 (permalink)
Easiest way without the need for a security code is to remove the head unit (you have to pry the plastic trim piece around the unit very carefully), leave the connector in the rear connected, and then take a voltmeter, select "continuity", and touch one lead to the metal chassis of the head unit and the other lead to a metal part of the Discovery. If you hear a long beep, it's got a good ground... If no beep, then start searching...
'03 Discovery HSE7 w/ACE and SLS...
jmrivera is offline   Reply With Quote
Comments/Suggestions [Post Here] rmuller Tech & DIY 29 04-20-2007 06:33 PM
What should I have done during maintenance? appstatedisco Discovery Series I 2 09-12-2005 07:57 PM
Intermittent Driveline Vibration at 60MPH AdrianL Range Rover Classic 10 06-24-2005 07:52 AM
I've fix it, here are the result $200 v $0 sidawson Discovery Series I 0 06-07-2005 10:46 AM
Problem with the window wipers JP-NORWAY Defender 2 09-02-2004 09:06 PM
